2011 half doors on a 2012 that came with full doors
I just got a set of used 1/2 doors from a 2011 and put on my 2012. All is good except the wire connectors are different and won't plug up to each other. The 1/2 doors only have 2 purple wires in a 10 pin connector, and the full 2012 doors had a 14 pin connector and I dont see 2 purple wires in either one of those. I was planning to just use a 2 wire connector for each door and connect them to the right circuits, but have no idea which wires to hook them to.
Any ideas?
Any ideas?
I wasn't aware of any wiring change for 2012, but if you dont like the half doors, i'll gladly take them off your hands. I wouldn't worry to much about wiring a half door, I think it is just for the interior lights when you open the door.
I agree, you don't really need to wire them but if you can figure out which wires on your 12 run the door closure switch it solves the problem of the stereo running for a couple minutes after you leave your Jeep.
There wasn't a Wiring change, just changing the Connector from a 10 pin to a 14 pin to handle the Extras added on the 2012....
Any ideas?
Any ideas?
