2010 U-Connect Help, what parts do i need
Old 09-09-2010, 05:19 AM
husker_fan's Avatar
Thanks for all the help, not sure if I am really thrilled about this project (rather spend my money on other mods) , but the help is very much appreciated.
Old 09-09-2010, 08:54 AM
Matt08jk's Avatar
If it is a 2010 with the Mygig, the mic and hands free are already there.
You need the module listed above and have it installed and programmed into functionality.
Just go to the mopar parts site and look up the wrangler Bluetooth accessories for PDF instructions to give you an idea of what you are dealing with.
I am in this same process, I am investigating a way to use all the pre-installed mic wiring and using the OEM a-pillar molding with the mic installed for a clean look. Will require a custom wire harness but I have time.
Good luck.
Old 09-09-2010, 10:52 AM
Rednroll's Avatar
Good luck.
You don't need a module for the MyGig if it's an RER. See My mods below=NO MODULE.
Old 09-09-2010, 11:06 AM
Matt08jk's Avatar
Thats correct, I stated hands free already built in, I was more emphasising that the 2010's have the mic too...nothing required. 2007 - 2009 require a mic. Agreed.
Quick Reply: 2010 U-Connect Help, what parts do i need
