2010 jku help
2010 jku help
Tail light help!
I bought a 2010 jku. The stock right taillight would go out and nothing else worked. Switched to led and the same issue. It will work for about 20 min. and go out. Turn key off and back on and it will work again. With it parked running with headlights and turn signal on it will work for 45min and I give up. I did periodically turn the signal off and turn wheels a few times and turn it back on and it stays on. Thought a ground so I tapped the ground to the body. Didn't help. Also did the restart while driving.( put in neutral and turned off ignition and restarted. Works again) Any thought?
