2008 JKUR Brake Lights Not Working (Third Brake Light Works)
I have searched everywhere I can think of and I feel like I have checked everything possible. Here's the issue, brake lights do not work but third brake light does and the turn signals work. Here's what I've checked or done, replaced the TIPM and did the soft reset/learning procedure, returned Jeep to stock with the flash cal and updated the firmware on the flash cal, replaced the brake switch, verified voltage to and from brake switch, verified voltage on the white and tan wire at the TIPM, checked the bulbs even though the turn signals work, disconnected the trailer harness. Still no luck, am I missing something simple? Any help would be greatly appreciated.
