2 mygig questions
2 mygig questions
1) if my JK, which came with a cheapie factory single CD radio gets a mygig, will I need to take it to the dealer ($$$) so they can starscan it to make it work?
2) which mygigs will work with an 09 JK? I know it has to be highspeed bus, and I have a list of the factory part numbers, but are all others with the high speed bus compatible as well, or just the original ones?
I see that the '09 wrangler in north america came with:
5064739AC
5064759AB
5064757AB
Seems like it's just a radio, shouldn't be so complicated.
thx.
5064739AC
5064759AB
5064757AB
thx.
1) No StarScan is required. I swapped mine right in and everything worked just fine. You will need to add a Nav antenna if you go with the Nav version and a Sat Radio antenna if you don't already have Sat. Radio. If you do have it, then your current one will plug in just fine.
2. Any high speed MyGig will work. The main difference are that the 08 Nav Units increased the hard drive to 30GB and in 09 they added the ability to charge/control and iPod/iPhone if you add the cable. The 07-08 units lack this functionality.
