Wiring cb to cigarette lighter
As the title says I am wanting to wire my cobra 75 to the driver side cig lighter because the power is cut to it After turning off the ignition. How do I remove the dash panels? I can't figure this one out. Is there an easier way?
It will reduce the noise on your speaker ans improve your SWR reading
I pulled only the very bottom panel off--just gentle prying. Was then just barely able to access the cigarette hot wire (blue/pink IIRC) by pulling it down below the panel it's mounted in into the now open space where I'd removed the panel. There's another similar wire, but not quite blue/pink (maybe pink/light green or something): Don't use it! I used a T-splice to tap into the blue/pink wire.
This is actually for mygig but it shows you how to access the panel.
http://www.coastaletech.com/WRANGLER_INSTALL.htm
