Baofeng GMRS no xmit to FRS radios.
Trail ride today, I have GMRS and everyone else had FRS. My radios are both Baofengs, a UV-5 and a more expensive BF-9 or whatever the model # is.
Both radios received FRS fine. Neither would transmit to FRS.
I had the correct freqs installed, in both radios and in both A&B in both radios.
The GMRS had no problem transmitting to each other.
Is this some kind of setting or something? I went through the manuals six ways from sunday but no joy.
Thanks,
Darel
Thanks,
Darel
@Darel Did you ever get it working? I know it's been a while since you posted, but I'm still new here and catching up.
Since you didn't state matching the privacy code, my first guess the FRS radios have a privacy code set and you have not matched that (analog or digital) code on your TX. If your RX has no privacy code set, you will hear all the radios on that frequency just fine since your radio is not restricting any input based on freq/code in the signal. I normally have one radio with no RX code set so I can hear if others are using the channel and get the group to move to another before it becomes a problem. You'll need to know the radio brand they are using and what the Code number converts to for the analog(freq)/digital(code). Once matched you should be able to TX/RX with them all just fine. The easiest way is to just have everyone disable they're privacy codes and they should hear you fine. But if you end up in a busy area, you'll hear everyone using that frequency, but that can be good if you want to stay on a quieter channel.
If they want to keep their privacy code, I know some GMRS radios can scan for the code, just set the ch-frequency, have one of the FRS user key-up and talk while you are scanning until it locks in on the code they are using. With my KG1000G once it locks in, I can key-up and set it as my TX code as well to join in quick and easy without needing to do the whole brand code Rosetta stone lookup and manually setting it. I think I can have it auto set the code to RX or RX&TX when I key-up as well, but I've not used it in a while and can't remember all the options off the top of my head.
OK, I also have a couple of Baofeng UV-5G radios that are locked into GMRS rules for TX and have not had any issue with them either, just not as auto without the code scan the KG has, but the KG can scan and I can punch them in on the handsets easy enough.
I believe some baofeng gmrs radios come with pl tones / codes programmed in from the factory, which limits any other radios unless they have the the same tones or codes. I seem to remember something about having to go in and clear the codes
Transmitting a PL Tone/code doesn't stop radios not set to filter incoming transmissions on the frequency to only the signals with the some PL. In most cases, if you hear their radio(s) and they don't hear you, they have the code set while you don't.
Dat (02-07-2024)
I’m going to have to do some digging around, there was something about the baofeng not transmitting, my memory is spotty on many things
Now I know there are some Baofengs that they have set up, around the time they released their UV-5G, so they cannot transmit on GMRS/FRS frequencies at all because they're not type-certified for it. Those radios can listen to GMRS/FRS without issue, but will not transmit on it.
That could be what I was thinking, not sure, and I’m not up on baofengs much, some people love them, some can’t stand them, haven’t ever used one myself. A few folks I know like them because they are cheap, if they loose it in the woods or on the river, no problem. I think even on those there was a way around the transmit that was simple, just hold different buttons while power on and it reset things. But then again, I’m trying to rely on memory and google and u tube don’t always steer you in the right direction
