Model 1100 Need Duck Advice...
I have a model 1100 that used to be my grandfathers. It had two barrels, one has "full" and the other had "imp cyl". Are either of these good for duck hunting? If not, what do I need to get?
The short answer to your question is "It depends on the weather.".
The barrel marked "Full" will have a tighter pattern than the "Improved Cylinder". If the weather is really clear you may be better served with the "Full" barrel and save the other for overcast days. Makes you really apprecaite interchangeable choke tubes doesn't it?
Although I was taught to shoot with a modified shooting pheasants, I went with a 30' full choke for ducks, even tho I did shoot a lot of pheasants with it as well. Duck hunting is quite a bit different than upland game, and there is plenty of times where the full choke can reach out and touch them, where a modified, or even improved wouldn't. It really depends on the situation, meaning....shooting over deeks or pass shooting. Just remember, that if you go with a full choke, the pattern will be real tight up close, so it's easier to miss, as well as easier to make mince meat out of a bird as well should it take the full pattern too close. Nothing wrong with the Improved either tho. I've kind of been out of that game for awhile, but if I recall the improved is a little tighter than modified and not as tight as the full. Either choke will do you right.
For what it's worth...I work for Remington.
Having to choose between the two, it is most likely that Full choke will serve your needs better. The Improved cylinder spread is between Cylinder and Light Modified and is quite open. You could always buy more barrels
Happy Shooting.
Happy Shooting.
full choke?
If you're using steel (which you should be) stay away from full. It will blow your pattern. With my bennelli you can't even use the full with steel. Go with a modified it will serve you in all situations!
That's right......I forgot all about that. Law is now you have to shoot steel for waterfowl. So you don't want to use a full choke and take the chance of bulging your barrel. But I have to ask.......hasn't steel shot come a long way in terms of buffers now? Does anybody shoot steel through a full?
