Gun safe shopping
#21
No one's brought this up but 1 other minor thing to think about _after_ you're pretty sure which safe you want to get.
If your safe will be somewhere damp -- basement, garage or even inside your house in some locales -- you need to deal with humidity inside the safe (& even condensation when there are quick temperature changes).
The 2 usual ways to do this are either a moisture absorber that you swap out periodically or a low-wattage bulb turned on inside the safe all the time.
Examples of the former are the Eva-Dry 500. May last a month or more inside an infrequently opened safe (YMMV) between "recharging" then use the built in AC plug to dry it out again (10-15 hrs depending on ambient humidity).
For the light bulb approach, almost all manufacturers can provide a hole for AC cord in non-fire safes & some will also offer for their fire safes. The hole is only big enough for the cord -- you wire it up afterwards. DO PLAN AHEAD -- you don't want to be moving the beast after installation so you can get back there to run a cord.
HTH!
HTH!
#23
Originally Posted by bloodhound351
Check out Lowes. they have liberty safes reasonably priced.
#24
I have a 24 gun Liberty that works well for my purposes. I think I paid ~$800 as a clearance item from Liberty direct.
One bit of advice, figure out what size you want and DOUBLE it! I'm wishing I had spent a few extra bucks for the next size up (or 2 sizes up!!).
A nice safe is a great investment.
Jeff
Jeff
#26
I have a Liberty safe and love it. I live about 30 minutes from were both Liberty and Cannon safes are made so I got to look at both first hand before I bought mine. Just like the security features I got with the Liberty safe better.
Also a tip for moving the safe if you get one of the big ones is use golf balls to roll the safe on. Another thing is select the place you want to put the safe wisely. they are no fun moving once you have them in place.
#27
I bought a Heritage safe. I can't remember why I went heritage over liberty. I paid between 1800.00 and 2000.00 for mine. It's been several years since I bought mine so I can't remember the exact price.
