Phoenix Area JK'ers Say your piece!
#6591
Originally Posted by jeepinJay
You need to relocate that steering stabilizer.
My jks track bar is only a 1/4 below that sector shaft brace I'm guessing that the bar is wrong. Im i correct thinking that
How much to get the tie rod you had made?
#6592
Originally Posted by Dblaron
Thats as high as i can get it without it hitting the draglink flip. Im gonna have to weld some tabs on to relocate. Is there another solution
You have a drop bracket on frame side and a bracket to raise your track bar on the axle side. That's why you are seeing the track bar 1/4" between them.
#6593
You need the same bracket I have. Puts it above the tie rod.
#6594
It looks like in your pic you have the track bar mounted to stock location with the flipkit installed. Since that makes your trac bar and drag link not parallel do you have problems with bump steer
#6595
You need a different track bar. Im not sure about the jks but that one is not going to work. as far as relocating the stabalizer your best bet is to fab up a new bracket and weld/attach it to your track bar bracket. It looks great and your geometry is perfect, it should drive great!!!
#6596
Also now noticed i need a front cv shaft mine is rubbing with caster at 6.5. Which one is best
#6597
It def drives a whole lot tighter and gives me comfort. Just need to figure out the track bar issue before i wheel. Is fine as long as sway bar attached. If not jks what track bar do you think would work best.
#6598
It's hard to tell from the pics but a Tera flex track bar might work. Your front driveshaft is rubbing on the cross member?
#6599
