Phoenix Area JK'ers Say your piece!
#5481
Originally Posted by Jknockers
I would gusset, both styles, one over the other, sleeve it and truss it. Get that front axle beefed up b4 it's too late and b4 gears. Then count on Ball Joints to be done soon. Also take a torque wrench to all the bolts under that thing , especially the front steering stuff and track bar. I am speaking from experience and wanna save you some headache.
Thanks again
#5482
Thanks on that thought I ordered the Purejeep truss with the Evo sleeves and gussets. My only worry now is I bought the jeep used with a mall crawler unknown lift and 35 I'm not sure if the c are bent yet. Can an allignment shop let me know if the are bent already. I jut put the 37 on and am not gonna wheel it till I get the axle trussed and geared.
Thanks again
Thanks again
#5483
This is what I would do if it was my Jeep, I would look it over very well, tires for rock scares, under carriage for scrapes, under axle tubes for rock rash, and if it all looked good I would just go ahead and gusset and truss it. If I had questions about anything I would run it through a alignment shop and have hm check it out and have them look at the Ball Joints while they are at it. They, the ball joints, if worn very bad can play he11 with you, as in tire wear and alignment and also cause death wobble. Gear change will run you around 1250. so if you only wanna get into the guts of the front end once and do all the gears sleeves (if you wanna do that also) then thats the extra your lookin at. Also who ever welds you gussets have them stitch weld them or have them remove your ball joints first then install the gussets and after it cools install some Heavy duty ball joints and be done with the ball joints once and for all. Things to think about cause if you wheel the thing you will end up replacing the ball joints.
#5484
#5488
That PR44 looks great.
Today I went out with a group of jeepers on Hackberry Creek. It started off as a nice day, but as the day went on it got foggy and rainy/misty. I remembered how much I hated wet rocks and open differentials. By the end of the day my jeep performed wonderfully and I was not amoung those towed or winched (Shocking, isn't it?) Though I was pretty stressed in a few places, my JK roared on through without any issues. I have to thank the spotters for my success.
I don't have any good action shots, but here are a few pics anyways.
#5489
Attachment 251533Attachment 251534Attachment 251535Attachment 251536Attachment 251537
