Four Corners If you live in the Four Corners area (Utah, Colorado, Arizona and New Mexico) and would like to meet some of the great JK-Forum members in your area and/or discuss upcoming trail events, this is the forum for you.
Phoenix Area JK'ers Say your piece!
Old 12-02-2011, 06:45 AM
  #5351
Croce's Avatar
I was thinking of that since i finally have a garage big enough to work on the jeep in. im just lacking the tools such as jack stands, floor jack, 16,18,21mm wrenches and sockets ect
Old 12-02-2011, 08:03 AM
  #5352
CrazyCasey's Avatar
I have all of that. If you guys want to make the drive to my place Saturday we can do it there. Wife is leaving for a christmas party around 11am. Ill be doing some wrenching of my own for a bit saturday
Old 12-02-2011, 08:07 AM
  #5353
remark's Avatar
All the tools required are easy to bring over to an install party.
However you may look at buying a few of them as time goes by. At some point you will want to check the tightness of a bolt, etc and will need a 18 mm socket or so. etc, etc.
Old 12-02-2011, 08:18 AM
  #5354
remark's Avatar
Are you doing your transfer case?
Old 12-02-2011, 09:34 AM
  #5355
CrazyCasey's Avatar
No im gonna let an expert handle that.... im gonna take a few other items off of this fancy jeep I bought. One if Which is the rear tuffy security drawer if any one is interested I don't think im gonna keep it
Old 12-02-2011, 09:44 AM
  #5356
Jknockers's Avatar
Transfer case spec.s:
CASE Material: 356-T6 Heat Treated Aluminum
Weight: 125 lbs. (dry)
INTERNAL COMPONENTS:
Gears: Helical Cut
Planetary Gears: 6 Gears Helical Cut
Bearings: Needle & Taper Rollers
Synchronizers: Borg Warner
Available Input Shaft Splines: 21, 23, 27, 29, 31, 32, 34
Tail Shaft H.D., 32 Spline 300M
Front Output 32 Spline
RATIOS:
Low Range: (2.0:1, 2.72:1, & 5.44:1) or (2.72:1, 3.0:1, & 8:16:1) or (2.72:1, 3.8:1, & 10.34:1) or (2.72:1, 4.3:1, & 11.70:1)
High Range 1:1
LUBRICATION:
Quarts: 2.5
Old 12-02-2011, 10:00 AM
  #5357
CrazyCasey's Avatar
Gears: Helical Cut
RATIOS:
High Range 1:1
LUBRICATION:
Quarts: 2.5
LUBRICATION..... Thanks Tim!!!! This one is the last set of ratios
Old 12-02-2011, 10:04 AM
  #5358
Jknockers's Avatar
No problem, my only concern was that it was OK inside. You hit a Homerun on this one.
Old 12-02-2011, 11:08 AM
  #5359
JK on 44s's Avatar
X2 on the homerun. Now you just need some stonger axles to handle the lower gearing....
Old 12-02-2011, 11:55 AM
  #5360
CrazyCasey's Avatar
Originally Posted by 4DARCKS
How much you asking.
I saw them online for like 650. I was gonna put it on cl for 300 but id take 250....
Quick Reply: Phoenix Area JK'ers Say your piece!
