Phoenix Area JK'ers Say your piece!
#5242
[QUOTE=SunnyD;2660390]Thanks for posting this dude!! Picked them up this morning
Glad you got them. That was too good of an offer to pass up. I really wished they were for a 2dr
#5243
#5244
BTW that is all i know about metal and I cannot even weld any kind of metal.
#5246
Its not a PITA, but will take some time if this is your first time doing it. Just follow the directions and you'll be fine. Theres nothing involved that takes a pro mechanic, but there are a lot little things that can bring the suck. Using the retainers are straight foward, but getting the nuts on some of the bolts can be tricky since theres not a lot of room to work with on the back side. A long, strong pair of needle nose will definatley help.
Heres the instructions just incase:
http://www.bushwacker.com/Instructions/10919_r5.pdf
Good luck!
Good luck!
#5247
One tip for you... If you are doing it on a cold day use a blow dryer to heat up the plastic retainer push pins right before you install. Otherwise you will end up with a bunch of cracked pieces of plastic in your hands. You'll play hell trying to find them at Pep Boys or the zone...
I can't wait to get them on... Probably going to have to wait until after Thanksgiving though... family coming into town
#5248
Hey guys I started my build thread. I still need to update it and add all the tech along with pictures of the process itself, but here it is:
https://www.jk-forum.com/forums/show...quot-tires-ect......
#5249
I was thinking about hitting up TM. I have to flex my legs a little bit to set my bump stops....
#5250
IM DOWN..... just let me know when. got my axle seals and control arm bushings fixed so im good enough to go. still need a tie rod and ball joints but they will work for now!!!!
