Four Corners If you live in the Four Corners area (Utah, Colorado, Arizona and New Mexico) and would like to meet some of the great JK-Forum members in your area and/or discuss upcoming trail events, this is the forum for you.
Phoenix Area JK'ers Say your piece!
Old 08-19-2011, 09:05 AM
  #4471
JKBobAZ's Avatar
Default Saturday corect??
We are talking about Saturday August 20???
I may just make it!!
Old 08-19-2011, 09:12 AM
  #4472
jlabe2's Avatar
Yes, Saturday, August 20th. Meet at 8:30 am at the Bush Hiway overpass on Hiway 87. Drive on to the trailhead (10 miles or so). Air down, lunch on trail, back in the Valley by around 2 or 3 pm. Sounds like 3 or 4 Jeeps so far. Anyone else?
Old 08-19-2011, 10:11 AM
  #4473
CrazyCasey's Avatar
dont think im gonna make it this weekend with the wifes b-day and all. the next chance I will have will be over the holiday weekend. if it cools off a little i will set up a run for bumblebee..... it will be a 5-7 hour run if anyone is interested in testing their jeep and nerves out to see what they can handle this is the place. it is tame enough for stockers but has lines that only buggys can do....
and a few jks
http://youtu.be/X9Cic8Kjcqo here is last years run... video by ORFAB and yes that is the Rustlers white jeep in the video....
http://youtu.be/pvN9gN1wdSU
Old 08-19-2011, 10:36 AM
  #4474
awesomo's Avatar
Default Resetting "change oil" warning
Anyone know how to reset the "change oil" warning on the instrument panel? Manuel says change every 8k but warning goes off every 3k.
Old 08-19-2011, 10:41 AM
  #4475
Croce's Avatar
Per the manual page 209
To reset the oil change indicator system (after
performing the scheduled maintenance), refer to the
following procedure:
1. Turn the ignition switch to the ON position (Do not
start the engine).
2. Fully depress the accelerator pedal slowly three
times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary repeat this procedure.
The engine oil change indicator system is duty-cycle based, which
means the engine oil change interval may fluctuate
dependent upon your personal driving style
So that means it will be displayed depending on how you drive. i always change mine when the indicator light comes on and not at the 6k/8k interval
  #4476
awesomo's Avatar
Originally Posted by knotaddicted
Awsomo: tires look great! You will be happy with them.
Jason: 7:15 at the pilot on 99th sounds good. I'll bring my swr meter so we can tune it if there is time.
Thanks Darren! As for 2morrow...im thinking i should get an alignment since I never got one after installing the lift. Especially now with new tires. Tim and I are talking about hitting the coves on Sunday.
Old 08-19-2011, 10:48 AM
  #4477
awesomo's Avatar
start the engine).
So that means it will be displayed depending on how you drive. i always change mine when the indicator light comes on and not at the 6k interval
Thanks Croce! Did u ever get a chance to work on ur jeep? I still have this clanking when i go over bumps or when i shake the jeep. Its comin from the driver side front wheel. Can an improperly seated spring cause this noise?
Old 08-19-2011, 10:53 AM
  #4478
Croce's Avatar
Ya Jason Installed my Springs/shocls for me last weekend...I still hear the sound when hitting speedbumps, Im starting to think its my trackbar hitting my front rockcrusher diff cover..
I dont think a improperly seated spring would cause the same sound im having, but its very easy to check if their seated correctly or not.
Just look at when the spring sits on the lower spring mount and see if its in the notch (ill see if i can find a pic to show you)
Old 08-19-2011, 11:08 AM
  #4479
Love Monkey's Avatar
and a few jks
Video Link: http://youtu.be/X9Cic8Kjcqo
Video Link: http://youtu.be/pvN9gN1wdSU
Sounds like fun! The Bradshaw run is the 3rd so keep it in mind too Casey!
Old 08-19-2011, 12:54 PM
  #4480
Originally Posted by 4DARCKS
Thinking us westside guys are going to do crown king instead tomorrow. I wont have time tonight to take off my top, doors and install my speed bumps. So far I think we have Bob, Darren and myself going. Easy trail for stockers. Who wants to join?
What time? and how long does it take?
I am going to one or the other I think, I just don't know which one now!!
Quick Reply: Phoenix Area JK'ers Say your piece!
