Phoenix Area JK'ers Say your piece!
#1651
Payette draw in may sounds good to me
#1652
PHOENIX JK's
OK Guy's I need some input! Here's the deal, I want to go to 37s but I have a D30 in the front. I'm already too far into the D30(ARB Locker,5:13s) If I sleeve & gusset and go RCV axles I will have a built D30.Will this be strong enough to WHEEL 37s? Even if I find a Rubi D44, ARB does not make a locker for a front D44. So what do you think? YEA! or NEA!
#1653
John, As you know I run 37's on a Stock D30 front (recent sleeve and gusset - only for peace of mind).
I have done allot of research on this subject (remember my Christmas list diatribe). I recieved a ton of advise but, the most sound advise came from Joe (Absolute). He explained the weak points of the D30 which, can never be fixed or masked - no matter what you do.
You will spend a ton of money and never have what you would need in a D30.
So, he said start with a D44 and build on that platform as it has bigger/better knuckles and joints. That is if you can find a new or used D44. If you do find one - you will find that in building one, you are going to be close to the cost of a Dynatrac Pro Rock 44 bolt on.
So, thats why i am not spending any money in my D30. I will either find a D44 and build or continue to save for a Dynatrac. (If my wife had it her way i would sell my Harley and/or Benz first.
As Joe explained, the D30 will be fine as long as I am not getting real crazy and dont thrash on it. Now you know why I dont take the same lines as you, Casey and others at times...
So, John stop spending money on the D30 as it will only make a loud flushing sound in the future.
But, dont take my novice advise - If you have some time go see Joe, as he holds much more credibility than I...
#1654
#1655
#1656
D30
Trust me guy's, I have been loosing 3 hrs of sleep per night researching this there is a lot on this topic so consider this: the D30 & D44 have the same housing, nuckles Cs, The D44 has a bigger pumpkin for the Ring, even the Pinion gear is the same size. With that being said, A D30 Sleeved w/C gussets(same kit as D44) RCV axles (same strength as D44) ARB Locker (Stronger than a Rubi E-locker) my only week point is going to be my R/P. At least I have a 5:13 and not the weak 5:38! So even if I find a D44 I will still have to Sleeve & gusset,RCV axle. In the end my built D30 will be stronger than a stock D44! Now you guy's can understand the TRAMA that I'v been goin through in my head! I go to bed thinking about it and wake up thinking about it, and oh yeah! ALL DAY LONG!!! Thanks for your input guy's. I havn't made up my mind yet, but am leaning to D30.
#1657
Trust me guy's, I have been loosing 3 hrs of sleep per night researching this there is a lot on this topic so consider this: the D30 & D44 have the same housing, nuckles Cs, The D44 has a bigger pumpkin for the Ring, even the Pinion gear is the same size. With that being said, A D30 Sleeved w/C gussets(same kit as D44) CRV axles (same strength as D44) ARB Locker (Stronger than a Rubi E-locker) my only week point is going to be my R/P. At least I have a 5:13 and not the weak 5:38! So even if I find a D44 I will still have to Sleeve & gusset,CRV axle. In the end my built D30 will be stronger than a stock D44! Now you guy's can understand the TRAMA that I'v been goin through in my head! I go to bed thinking about it and wake up thinking about it, and oh yeah! ALL DAY LONG!!! Thanks for your input guy's. I havn't made up my mind yet, but am leaning to D30.
#1658
John, I have the D30 sleeved and gussetted and I don't think I would go bigger than 35. I think Dynatrac axle or Ford axle reworked would be the way to go.
#1659
I have seen guys run 37's on a d30 with no preblems just depends on how you drive. But I wouldent upgrade from a 30 to a rubi44 to me its a waste of money go with a aftermarket 44 there is a good selection to choose from. If you don't want to spend that much you could always go the junk yard route and get an older bronco f150 or 250 44
#1660
John everyone has already said what I agree with... the D30 can be a waste to do much more work on. On the other hand I have seen you offroad and though you take some really fun lines you don't abuse the skinny pedal. I am not saying that you might not get too much torque and grip with deflated 37s which can make everything go boom. What I am saying is you have a good chance to run you jeep with 37s and not have any problems.
