Official VA Thread
#1002
Going to pick up my freedom top from Jagermeister427 today. Pretty pumped. Hope it is in pretty good condition. I would hate to drive 9 hours round trip for nothing.
#1003
Originally Posted by Battlefrog
You should be fine with that and the Hemi will def help as well. It's not horrible as long as you know beforehand that "low/high blues" don't really exist.. It's pretty much low to high blacks.. I'd love to run it again, I'm just not set up for like I'd want to be.. I'm running a D30 and it really needs to be sleeved and gusseted for that run.. I've seen your setup when we went to the beach and you will be fine.. The lockers and 37's are going to make a huge diff..... Take some pics!
Was fun but I will not go back with a JKU.. You need a 2 door for most of it.
#1004
Originally Posted by duglas
Well went to Crozet yesterday, had a good time most of the day, only did low and mid blues most of the day. Then around 3 I went on a low black stream bed trail, boy was that a mistake. Destroyed both Side rails/steps and rock rashed both rear rims all the way around.. I also had to use my rear bumper to push/slide a huge rock out of my way. I also actually got my steering arm stuck inside a tree trunk and had to high lift off it and messed my alignment off bad. It was dark when I left and cold so I went to Merchants and got an alignment instead of doing another "trail alignment".
#1006
Originally Posted by ty01
hey whats going on guys? anybody planning a trip soon?
#1010
Is Uwharrie something I can do stock or able to bypass obstacles too much for stock? Not sure i will have the lift and tires installed by 6th. Maybe... maybe not.
