Long Island, NY
Old 02-18-2013, 03:17 PM
  #7511
conifers4's Avatar
Originally Posted by Cam36
Apparently there is a big meet this Thursday night at the Applebee's on DPA, anyone heard about it and is anyone going?
In the dead of winter??
Old 02-20-2013, 04:18 AM
  #7512
greenmachine13's Avatar
Ugh Wednesdays
ID:	424550   Click image for larger version
Old 02-20-2013, 04:34 AM
  #7513
conifers4's Avatar
Originally Posted by greenmachine13
Ugh Wednesdays
Sucks man, woke up to the same thing last week. Changed a 35 in the snow...stunk
Old 02-20-2013, 05:13 AM
  #7514
I have a question for you or anyone that can help me cause I'm a noob. When I tried to jack up the tire the jack from jeep didn't go high enough to get the tire off the ground. I wound up borrowing a hydraulic floor jack from a salvage shop that was across the street from where I got the flat. Anyone recommend a good jack that I can keep in the jeep that will go high enough and isn't too heavy or bulky. Somebody suggested jacking it up from the axel but I wasn't comfortable doing that with the jack from jeep.
Old 02-20-2013, 05:30 AM
  #7515
Hammerstien's Avatar
http://www.quadratec.com/products/92200_700_07.htm
Compact and I'd say cheap but $50 for a plastic base....
Old 02-20-2013, 05:34 AM
  #7516
conifers4's Avatar
Good question, I'm sure you will get many different answers. I myself use the factory jack under the axle. (No problems) Under the jack I use a board that I keep in the rear of the Jeep (piece of a 2X12) to gain just a bit of height( only talking an 1 1/2''). I really keep it in the back in case I have to jack up (not off) on sand or mud. Would never use a hi-lift to change a tire unless I HAD TOO!! Remember you won't have the luxury of a floor jack if/when your stuck on the side of the highway. In addition I keep a breaker bar in the back which makes things easier as well.
Old 02-20-2013, 07:31 AM
  #7517
lijeepguy's Avatar
i keep a hydrolic bottle jack in the jeep , also a board and more often than not jack it from the axles , bought mine on the cheap from harbor frieght , under $20 , good luck
Old 02-20-2013, 08:10 AM
  #7518
Tanman823's Avatar
This is exactly what I use with my lift and it hasn't failed me yet, really sturdy and tough. Used it in sand snow and pavement
Old 02-20-2013, 08:14 AM
  #7519
Tanman823's Avatar
Also designed to fit perfectly in the truck storage compartment so it's not just out and about
Old 02-20-2013, 11:25 AM
  #7520
Ronjohnjk's Avatar
I have a hi lift jack mounted to my hood. Takes a few min to unmount but looks good and works well. I used it to rotate my tires when it was still warm out. Kinda hard to see but the design on the mounts is a skull and cross bones
ID:	424673   Click image for larger version
ID:	424674   Click image for larger version
ID:	424675   Click image for larger version
ID:	424676   Click image for larger version
Quick Reply: Long Island, NY
