Long Island, NY
#7511
I have a question for you or anyone that can help me cause I'm a noob. When I tried to jack up the tire the jack from jeep didn't go high enough to get the tire off the ground. I wound up borrowing a hydraulic floor jack from a salvage shop that was across the street from where I got the flat. Anyone recommend a good jack that I can keep in the jeep that will go high enough and isn't too heavy or bulky. Somebody suggested jacking it up from the axel but I wasn't comfortable doing that with the jack from jeep.
#7515
Compact and I'd say cheap but $50 for a plastic base....
#7516
#7517
i keep a hydrolic bottle jack in the jeep , also a board and more often than not jack it from the axles , bought mine on the cheap from harbor frieght , under $20 , good luck
#7518
http://www.quadratec.com/products/92200_700_07.htm
#7520
I have a hi lift jack mounted to my hood. Takes a few min to unmount but looks good and works well. I used it to rotate my tires when it was still warm out. Kinda hard to see but the design on the mounts is a skull and cross bones
