Long Island, NY
Old 06-19-2012, 04:07 AM
  #6851
MikekiM's Avatar
Originally Posted by just words
Just got a 3" lift done today at rms. need to go drive over things
Lot's of hyundai's and honda's around.. Just watch you don' high-center..
Originally Posted by conifers4
Mike I'll take that muffler, hopefully we can just meet up this weekend.
It's yours. Shoot me a PM with a few times that work for you. I am probably tied to my house for at least most of Saturday.. A few projects on my to-do list..
Old 06-20-2012, 06:18 AM
  #6852
2010islander's Avatar
Easy, yes. But i think the Ace sliders look like ass unless they are mated to a set of... Rubi rails. That brings me right back where I started. Plus, I want to weld them myself..[/QUOTE]
I here ya looking into buying a tubing bender to weld up a pair myself
Old 06-20-2012, 06:36 AM
  #6853
MikekiM's Avatar
I here ya looking into buying a tubing bender to weld up a pair myself[/QUOTE]
If you other needs for a tube bender go for it.. otherwise, there are numerous vendors who make the kits for converting the Rubi rails.. All are around $200 bucks for a two door.. so if you there is no need for the tube bender going forward, might be less expensive to just buy the kit. Or if you're going to spend the money, you could just buy a set of SRC Side Armor.
Old 06-20-2012, 10:42 AM
  #6854
conifers4's Avatar
PM sent MikekiM
Old 06-21-2012, 04:28 PM
  #6855
JK4x4wrangler's Avatar
Default Gear change on an auto
Can anyone recommend a good reasonably priced shop on LI for a gear swap, its for a friend's 11 JKU.
Old 06-21-2012, 06:12 PM
  #6856
powrsurg's Avatar
I think Evan does these as well. 516-384-5349. If he does, his prices will probably be the best.
Old 06-21-2012, 06:15 PM
  #6857
Thanks, just one question, who is evan, and where is he located?
Old 06-21-2012, 06:31 PM
  #6858
MikekiM's Avatar
There are two or three shops on LI that are well trusted and recommended.. Evan is in Western Suffolk is probably at the top of the list when it comes to our needs..
Bill.. Great to meet you tonight!! Thanks
Old 06-21-2012, 06:39 PM
  #6859
powrsurg's Avatar
Same here Mike. Good luck with your project. I look forward to seeing the outcome.
Old 06-25-2012, 04:52 AM
  #6860
MikekiM's Avatar
Well, if anyone with a two door is looking to add Rubi Rails, but can't locate a set.. The JKU rails will work just fine.
Cut about 19" off the back end of each rail and mounted them with no problem. Chopped the pinch seem to match the rails length.
Everything lines perfect.. Next up, Poison Spyder Rico Steps!!
Quick Reply: Long Island, NY
