Long Island, NY
#5401
If they are a MAXIMUM of 4" backspace, they should clear. Some people had no issues with 4", some did. I have 15x8 with a 3.75" backspace and STILL had to shave the front caliper brackets down a hair. Even if you need to grind the caliper down, who cares...anything fits with a little cutting here and there.
#5404
soo i ran into some friends on the beach today, and they both told me that jeep has or is coming out with a flat black jk ????? is this true or were my friends really THAT hammered? ha ha
#5405
#5406
Nothing a case of rattle can flat black can't fix. Too much hassle trading in a vehicle just for another color, and talk about taking a loss.
I doubt Jeep will ever come out with something like that...it's too "extreme" for them.
#5408
Installed a York 206 OBA setup in the JK. Got the 206 for $30 from my friend who loves collecting parts from older AMC/Jeep. Used Off Road Only's bracket kit and Woods/JeepSwag air manifold. Check valve and oil separator from Grainger. 5 gallon air tank reserve from Sears. Used a 5,000 PSI hydraulic hose as the output form the compressor (gets VERY hot VERY fast). Steel braided, holds the pressure and heat MINT. The rest is 3/8" 300 PSI line. Run 150 PSI pressure switch. Airs the 5 gallon tank in 2:18. Airs a 35" MT/R from 9 PSI to 28 PSI in 1:32 on idle. Run my 1/2" impact with no issues and plenty of reserve on the tank for all 5 lugs. Trail repairs will be MUCH faster now. Removed the head cover and drilled/tapped for 3/8" NPT. Created and welded my own brackets for the check valve and oil separator.
I don't care what anyone says, belt driven compressors are the way to go. I've had ARB electrics, Harbor Friehgt electrics, they are NO comparison.
Total cost was $490 vs. $1,100-$1,200 from Kilby/ORO. If you can make things yourself...do it.
#5409
Might be a bit late, but the weekend of June 4,5 and 6 myself and LIOR are heading up to Mettowee ORV for the weekend. About 15 people so far. Camping Friday night and Saturday night, wheelin' Saturday only, returning Sunday. Campfires and BBQ both Friday and Saturday night. If anyone is interested, let me know.
#5410
i just changed the diff oil in the jk, and when i pulled the rear drain plug the magnet was covered with chunks of metal not filings of metals, ill post a pic later but do u guys think it mite be a problem? thanks
Heres the pic i put a pen cap in the pic to show the size of the pieces
