Long Island, NY
Old 03-22-2010, 04:47 PM
  #4881
racer83l's Avatar
Originally Posted by nlgrav182
As much as I like the wave, I'm going to say that she was a prowling cougar and wanted you like a glass of pinot grigio.
Definetly the funniest thing I read in days.. Got anything else??
Old 03-22-2010, 04:48 PM
  #4882
Suffolk JK's Avatar
Seth, that part number comes up as a stability control module. They replaced a sensor or a module?
I think I might need to check my connection when I soldered a new wire on. It was cold at the time so I quickly spliced it. I think I might have a bad solder which is causing the ECU to go haywire. It comes and goes when it feel like it. If it doesn't fix the problem, then I'll take it in. $100 for the part or I give it to Jeep and still have to pay the $100 deductible for them to fix it.
Old 03-22-2010, 04:50 PM
  #4883
racer83l's Avatar
You needed to solder on the new ABS sensor?? I thought it was a sensor and about 2' of wire that just plugs into the Jk...
Old 03-22-2010, 04:57 PM
  #4884
DrewsJK's Avatar
awesome i like the way you think
Old 03-22-2010, 04:59 PM
  #4885
Suffolk JK's Avatar
Rear sensor's wire got cut a while back. Stuffed the tire enough to catch the wire between the bumpstop and bumpstop pad. Cut the wire clean in 2. Soldered a wire in between.
Old 03-22-2010, 05:20 PM
  #4886
Sethc84's Avatar
Here is what my paper work says (Verbatim):
Cust states check dash lights came on for esp and bas.
Fault C123C Dynamic sensor performance
Performed Diagnostic and Found Sensors Defective
Replaced Dynamic Sensor
Configured
Verified Correction
Operating As Designed
Part: 56029427-AA
Description: Module El 8035030
Hope that helps.
Old 03-22-2010, 05:37 PM
  #4887
DrewsJK's Avatar
so did anyone get their beach pass yet?(for robert moses)
Old 03-22-2010, 06:48 PM
  #4888
mattyhfd's Avatar
Matt, did you get the all in one package from Quadratec for the cb/antenna? Is the antenna a Firestik (ie. is it tunable)?
yea dimitri, it was the all in one cb set up from quadratec. yea its a firestick. i was told to have it tuned, but i have no clue how to do it or to tell if it can be tuned or not.
Old 03-22-2010, 06:49 PM
  #4889
mattyhfd's Avatar
Were you at the holbrook FD at like 2pm? I drove by and think I saw your JK
yea joe, that was me. haha what were you doing over by the firehouse?
Old 03-22-2010, 06:55 PM
  #4890
racer83l's Avatar
Stopping by a customers house to perform a quick service..
And take the rubber tip off the end of the antenna.. There should be a screw adjustment.
You need a SWR meter to adjust it. I have one bouncing around in the back of my JK. also, radio shack at waverly and sunrise sells them if you want to buy one
Quick Reply: Long Island, NY
