Long Island, NY
Old 01-29-2010, 07:20 AM
  #4181
BBirish's Avatar
dont forget PICS PICS PICS and congrats
Old 01-29-2010, 07:30 AM
  #4182
DrewsJK's Avatar
it will be the second thing i do as driving it home will be the first one
Old 01-29-2010, 08:24 AM
  #4183
BBirish's Avatar
did you pick tires yet?
Old 01-29-2010, 09:03 AM
  #4184
racer83l's Avatar
aaahhhhh so im running my stock lower control arms again... this wind and the lack of castor is making my JK plain hard to drive.... Im debating cutting the front axle brackets and installing the cam bolts that came with my AEV lift until I can get the LA kit.. (which I didnt pick out.. thinking rock krawler)
Old 01-29-2010, 09:24 AM
  #4185
mattyhfd's Avatar
just wanna point out to everyone that the winter Xgames is sponsered by Jeep this year and Sean White rolled into the xgames in a hooked up 4dr rubi.
Old 01-29-2010, 09:47 AM
  #4186
BBirish's Avatar
just wait til the LA, i heard some bad stuff about cam bolts
Old 01-29-2010, 01:50 PM
  #4187
Suffolk JK's Avatar
Just installed the IPF headlights, had to cut the little end off the connector to make it fit properly. Used Northridge's advice on the zip ties. They look GREAT!!
Old 01-29-2010, 01:53 PM
  #4188
Suffolk JK's Avatar
Drew, you had a shop install the lift?
Old 01-29-2010, 01:56 PM
  #4189
racer83l's Avatar
I also installed mine, it's cold out... Didn't adjust them yet. I'm going to dinner soon so I'll see how they are then.
Old 01-29-2010, 01:59 PM
  #4190
Suffolk JK's Avatar
You need to adjust them? The housing don't get thrown out of whack when you remove them from the "frame". The frame has the 2 torx bolts to pivot up and down and left to right. Once you plop them in, they should be in the same pitch as the OEM housings.
Quick Reply: Long Island, NY
