Long Island, NY
#4184
aaahhhhh so im running my stock lower control arms again... this wind and the lack of castor is making my JK plain hard to drive.... Im debating cutting the front axle brackets and installing the cam bolts that came with my AEV lift until I can get the LA kit.. (which I didnt pick out.. thinking rock krawler)
#4186
#4187
Just installed the IPF headlights, had to cut the little end off the connector to make it fit properly. Used Northridge's advice on the zip ties. They look GREAT!!
#4190
You need to adjust them? The housing don't get thrown out of whack when you remove them from the "frame". The frame has the 2 torx bolts to pivot up and down and left to right. Once you plop them in, they should be in the same pitch as the OEM housings.
