Long Island, NY
Old 01-16-2010, 01:39 PM
  #3951
Suffolk JK's Avatar
Looks good Brendan, when are you putting them to use?!?
Thanks for the parts Joe, didn't think you were dropping them off today!
Adam, those guys build show trucks that are 10 feet off the grounf, not needed. I wouldn't trust them nor talk to them seeing how they treat other people.
Just put a TF SS on order. DW is gone but still have a TINY TINY shimmy only over potholes. Damn sure it's the SS.
Old 01-16-2010, 01:52 PM
  #3952
BBirish's Avatar
Thanks, im guessing feb ill prob make a rc run
I have a TF SS, its definitely better than stock and should get rid of the shimmy
Old 01-16-2010, 01:53 PM
  #3953
BBirish's Avatar
Originally Posted by DrewsJK
ok so these are wheels i want i am getting them in 16x8 and with the wheel ring.. i just can't decide on the color. if i do the black i want to make the ring steel blue. lets hear your input
i think the silver would look good with the steel blue
Old 01-16-2010, 02:03 PM
  #3954
Suffolk JK's Avatar
Brendan, the rails bolt to the pinch seam or the frame? Looks like there's some pinch seam connections there. How are the nutserts? Easy to get in and lock up? Did you cringe when you started to drill holes in the JK?
Old 01-16-2010, 02:06 PM
  #3955
racer83l's Avatar
BB Very nice!!! Im hoping that side was a bit easier than the other side...
  #3956
Raf
Raf's Avatar
Looks good Brendan! One quick question is there a gasket of some sorts that goes around the rocker panel so this way there isnt any dirt that gets in between the body and panel? Probably going to order a bunch of stuff this week including rails/panel from ORV.
Drews if you want a blue ring I think silver would go best fella.
Old 01-16-2010, 02:08 PM
  #3957
racer83l's Avatar
Raf, did you drive down 25 near 83.. I think I saw you drive past my store maybe like 3PM
Old 01-16-2010, 02:15 PM
  #3958
Suffolk JK's Avatar
Joe, should've told me you were passing by, I would've left my swaybar with links out there. I'll do a drive-by this week after work and drop it off.
Old 01-16-2010, 02:26 PM
  #3959
Raf
Raf's Avatar
Yup that was me man
Old 01-16-2010, 03:01 PM
  #3960
BBirish's Avatar
the rails bolt to the pinch seam and body- VERY STRONG. The nutserts are tough, they are very time consuming but once we figured it out it went a little faster. And I didnt even cringe while we drilled 26 holes for the armor and enlarged 12 in the pinch seam and added a hole on each side also lots of drilling. Its just kind of unsettling knowing theres no going back.
This side was way easier, everything lined up had it done in 2 and 1/2 hours
Thanks there is no gasket, the armor is so tight against the body that I dont think anything will get in there
Quick Reply: Long Island, NY
