Long Island, NY
Old 01-09-2010, 07:44 PM
  #3821
mattyhfd's Avatar
is it really that easy?
Old 01-09-2010, 07:58 PM
  #3822
Suffolk JK's Avatar
If you have a nice cut-off tool, a nice tape measure, yeah...it is.
Old 01-09-2010, 08:23 PM
  #3823
Viper64's Avatar
My friend said the hardest part for him was just creating the cut out in the hood for him, other then that it is very simple.
Old 01-09-2010, 09:38 PM
  #3824
adamisadam's Avatar
wow, 401 pages & 4,000+ posts!
Old 01-10-2010, 12:56 AM
  #3825
joey2times's Avatar
YOOOOOOOOOO yOOOOOOOOO from Europeeee
hahaha Whats good team ???
Just figured I would drop a line.... once I get settled in more I will be posting on the forums a lot more....
havent even hit barca yet.... but shredding the swiss alps and rocking out in Ireland and Austria ahahahah
DAMN!!!! TONS OF NEW PAGES TO READ UP ON!!!
looks like I will have something to do for a while when I get to barca on tuesday!!
Old 01-10-2010, 03:47 AM
  #3826
Suffolk JK's Avatar
Just rub it in Joey, rub it in...
Thought you went there to work? Yeah right, you're screwing around with the Swiss bunnies. You bastard you...
Old 01-10-2010, 04:20 AM
  #3827
adamisadam's Avatar
Joey,
don't rub it in too much or we'll go fine your JK and mess with it. Like maybe we'll remove your new lift & return it to stock!
Old 01-10-2010, 07:02 AM
  #3828
Raf
Raf's Avatar
I second that
Old 01-10-2010, 07:24 AM
  #3829
BBirish's Avatar
x2 adam wow 4000+ posts in the Long Island thread!!!!!!!!!
haha joey sounds awesome, i love ireland i would probably move there if i could.
Old 01-10-2010, 07:29 AM
  #3830
racer83l's Avatar
Snorkel install is easy. It comes with a template.
What I did was cut out the template, tape it where it is supposed to go.. Now with the hood open, install the snorkel where it's supposed to go. Then close the hood. It's pretty easy to see by eye I the template is in the right place. Then I took a sharpie and traced the template in case it moved during cutting.
I used a dremel cut off wheel with EZ lock. I went through maybe 6 discs doig the cut. I liked the dremel because it's small and easy to make the turns. Took about 30 minutes to do the cut. Another 10 to file smooth the cut and paint.. Then you install the trim ring (will need a rivet gun) and install seal the snorkel to the airbox. Now take it for a drive and smile at the engine making a nice roar under throttle.
Quick Reply: Long Island, NY
