Long Island, NY
Old 11-24-2009, 11:42 AM
  #2911
can10's Avatar
Originally Posted by Sethc84
Yes, I have wheeled before but I have never been to Rausch. My last trip was in the back woods of Penn. right outside of Philadelphia. The guy I was following went through everything hoping I'd get stuck... never did. They hated my "dodge neon with 4 wheel drive".
I will go where ever I feel comfortable. If that means a bypass or two so be it. Rather the verbal abuse than the Bill. It really depends if I'm able to get my rock rails mounted.
Was anybody interested in the Misch Arm Rest?
im fine with that...and yes...i know..being the passenger..im fine with takin pics and what not
Old 11-24-2009, 01:29 PM
  #2912
Suffolk JK's Avatar
You won't get verbal abuse. Better safe than sorry.
But, if you have time, won't mind coming out by you to mount the rails, even if you haven't welded the bottom tabs.
Old 11-24-2009, 01:40 PM
  #2913
DrewsJK's Avatar
i have a tow strap, hi-jack and some tools and of course the tp is prob the most important thing lol and the teraflex leveling kit so that will give me another 2inches or so
Old 11-24-2009, 01:41 PM
  #2914
Sethc84's Avatar
I just got home and I'm going to do a test fit to see what size hardware I need. Do you think it would be alright to run them the way they are without the additional support?
Old 11-24-2009, 01:45 PM
  #2915
Suffolk JK's Avatar
They'll definitely be fine. Did he include the hardware? There's some strip nuts that come with the rails. They are strips of metal welded to the nut so you can snake it through the frame to the opening, and start the bolt.
On some holes, 1/2" grade-8 and grade-8 ONLY, bolts/washers/nuts. On a couple of the smaller holes, I believe 3/8", but, drill the holes a tad bigger to accept 1/2".
Old 11-24-2009, 01:51 PM
  #2916
DrewsJK's Avatar
should i remove my side steps??
Old 11-24-2009, 01:55 PM
  #2917
Suffolk JK's Avatar
It can go both ways. They can protect your body if you do decend on a rock, but then they'll crack and break to pieces. Your call.
If you trust our spotting, take them off. If not, leave them on. IMO, seen quite a few break to pieces, but with shitty spotting.
  #2918
BBirish's Avatar
...Yep.....
Old 11-24-2009, 01:59 PM
  #2919
Sethc84's Avatar
yea I just got back inside. First I thought the rails would line up with existing holes. Since I will have to drill the frame, I will wait for daylight or a garage. Its just not going to work out in the driveway tonight. Did any paperwork come with the rails that indicated exact sizes on these grade 8 bolts? Where can I even buy grade 8 locally? If you had a garage Dimitri, I'd come to you.
Otherwise here is the list of things I wanted to get done before Friday.
-Install mopar rubber liner (hide cb coax)
-Tune CB
-Wire My winch (what size inline fuse does everyone recommend?)
-Install Rock sliders
Old 11-24-2009, 02:13 PM
  #2920
Suffolk JK's Avatar
I installed mine in the driveway, alone. The paperwork, don't know where it is. But you can use standard 1/2"-13 grade-8s available at Home Depot and Lowes. They bolt up to existing holes. You can mount the rails, THEN use the holes on the plates as guides to drill the frame
I didn't install an inline fuse for the winch, I don't think ANYONE does. Not needed.
Quick Reply: Long Island, NY
