Long Island, NY
#2411
Can, if you air down your tires, you should use 4HI to keep up momentum. If your lazy like myself I use 4HI and esp off and dont air down, but if i feel like the sand is really soft and the jeep is having a hard time i put it in 4LO just incase
#2412
Use 4-Hi in sand and hold the esp button until it dings to disable it or else it will drive you nuts in the sand. You dont need 4low unless you are doing crawling or have lockers that you want engaged.
I cruise around all day on the beach in 4Hi ESP off and 33 psi without any probs. You should be ok at 18psi on stockers, you can go down to 15 or so. I like to go back to 2Hi if I hit firm ground so it doesnt bind when doing tight turns.
Joey2times Supports this post !!
#2414
#2416
Does anyone know a place where you can wash your own jeep with the powerwasher gun things ???
I dont want to take it to a carwash but I need to clean it up at this point because its still got 2 inches of RC mudd all over the entire thing... hahaha
I also need to clean all the mud off the dash and the seats and inside of the doors and what not but thats easy to do with wipes at home...
I need like a do it your self wash on long island with the guns and stuff...
anyone know a spot ?
#2418
#2420
o yea i forgot you lived in huntington, shoot down the 135 get off at hemp tpk and go to bubble up its prob the closest
