Long Island, NY
#1941
Hey guys, I am coming home (rocky point) the weekend of the 18th of september and wanted to see if any of you guys had any wheeling plans? When I was home last I did some wheeling out in manorville, and rained like hell so it was nice and muddy . where else do you guys wheel?
#1943
I used to run Smith's point all the time, but I don't have a pass anymore. What is the deal with JKFest? I am just coming home for the weekend, but I would consider coming back down again for sure if this JKFest is gonna be good
#1944
Beach - Sore Thumb
I still haven't purchased a portable air compressor, after you get off the beach where do you guys go to fill your tires back up? Also, what psi are you guys dropping too? I took mine down to 18psi, wondering if that's to low.
#1945
I have no idea about airing up, at smith point they have air..
#1946
Even if I'm at Sore Thumb, I drive over to Dem Point to air up instead of using my cheap, emergency only air compressor.
The beaches suggest running at half the max tire pressure that is on your sidewall. Anything from 15-20 or so is fine. the LT tires have much stronger sidewalls and can be run very very low without issue. P tires will be better at 18 than 15. Then just take it slow (ie, under 50mph) when driving from Thumb to Dem Pt.
#1947
Thanks, I drove to the nearest gas station (low speed) which is what I'll do today. Just ordered a Superflow portable air compressor online, I couldn't find a decent Compressor in any of the stores (Pep Boys, Sears, Auto Barn.)
I was wondering if I could run with 25-28psi on the beach without worrying about getting stuck. The side walls on my 33' ProComps say a max of 65psi, but I only fill them to 40psi.
#1948
#1949
#1950
Happy to hear about not airing down at all, I'm going to try 30psi today. I'll shoot you an email to pull me out if I get stuck
