4WD Hardware Eastcoast JK fest- October 10-12, No cut off date to register
Old 10-07-2008, 01:30 PM
  #981
bly109's Avatar
Originally Posted by ShadedOutDoors
Just got done putting on my A to Z Fab sliders was'nt to bad took about 3 1/2 hrs
with an extra set of hands. Extended the brake lines, and installed rear coil
retainers ahhhh. What I still got left to do-- put on the rear track bar bracket,
weld on JKS rear track bar brace, and then Rockhard front skid install
geeeszzz Im almost there
Your list is worse then mine Im almost done though, I just have to install my tire carrier, its currently sitting on my porch I also have EVO's c-gussets to install, but I know Im not going to get my hands on a welder until next week. So those will have to wait. Good luck with your list!
Old 10-07-2008, 01:32 PM
  #982
ShadedOutDoors's Avatar
Hopefully get it all done, not sure about welding the brace that may wait but most def the trackbar bracket and front skid I want all the armor I can get
Heres the new sliders
Name:	IMG_0231 (675 x 506).jpg
ID:	13853   Click image for larger version
Name:	IMG_0233 (675 x 506).jpg
Old 10-07-2008, 01:52 PM
  #983
acelockco's Avatar
They look great, I love the look of your Jeep.
It sounds like it took a long time for you to install those, is it a really involved install or what? I figured a few bolts and you would be done.
Old 10-07-2008, 06:27 PM
  #984
04DrBlur's Avatar
Well hopefully my JK is ready. Trailer is loaded and goin to roll out tom. after work. See you guys there.
Old 10-07-2008, 07:25 PM
  #985
Dirty Dog's Avatar
Originally Posted by O2BDrty
Been to RC before and didn't have a problem then. Problem is getting them here and installing them and time IS running out. We leave Thursday so no real time
The wife said to get it done so tomorrow new brake lines!!!!!!!!!!!
Old 10-07-2008, 07:40 PM
  #986
Shifty_42's Avatar
just a few more days!!!!
Old 10-07-2008, 07:43 PM
  #987
paramaniac's Avatar
Originally Posted by acelockco
Can you use the side steps with this as well? I noticed someone is giving away a set on the forum.
i have a set of steps, in fact, the last time i went wheeling, i forgot to take them off and cracked the passenger side step. i havent figured out if i can run both, id need to see if the studs on steps are long enough to pass thru the slider and the body and still get tight enough on the bolt. either way, i dont want the steps on for the trip, so im in no rush!
Old 10-07-2008, 09:08 PM
  #988
acelockco's Avatar
Yea' not if they are going to get toasted on the trail. I think it actually tells you to remove them for off roading in the the owners manual, but who is going to go through that every time you go on the trail. I guess when I break mine it will be time for an upgrade to something stronger.
Old 10-08-2008, 12:59 AM
  #989
Eternal ***erator
HappyCurmudgeon's Avatar
That is my plan. I have replaced mine twice (actually got freebie takeoffs to do so), i am on the third set?, there wont be a fourth.
Old 10-08-2008, 03:06 AM
  #990
Dirty Dog's Avatar
I keep dreaming of rocks and I don't know why
Quick Reply: 4WD Hardware Eastcoast JK fest- October 10-12, No cut off date to register
