4WD Hardware Eastcoast JK fest- October 10-12, No cut off date to register
#381
come on guys the purple trails ain t that bad! even the blacks ain that bad. i just don t like off camber crap. i haven t been on a wheelin trip yet that i havent come home broken.
trip 1 ruined clutch= new clutch under warranty
trip 2 ruined clutch, ripped off evap can, and had a bout 2" of mud in my gas tank all from hummer hole (check out avatar)= cost me $700!
was your evap canister covered? I know they covered mine when I cracked it and almost ripped it off. That picture is insane! GOD it would suck to be your jeep at that time! Was your engine okay?
trip 3 ruined front diff cover, front driveshaft, dented both rear shocks, bent tie rod in a u, really tested out my rocker guards= $about $200 for new tie rod setup from rock krawler.
ok, so maybe blacks do tear stuff up, but that is what a jeep is for right!
#383
just spent the day wheeling at Rausch Creek on the 27th. spent teh day on black and some red trails...cant wait to go again in Oct
http://www.youtube.com/watch?v=rcaiqM-1FU8
http://www.youtube.com/watch?v=IzzkOk44TiE
http://www.youtube.com/watch?v=w1Fq_6itydY
http://www.youtube.com/watch?v=hC8UjtmF1ls
07 JK Unlimited
3 inch BDS suspension lift
33x11.5x16
JKS Quicker Disconnects
Warrior Products Tube Doors
Mopar Off Road Rear Bumper
Oil Pan Tranny Skid Plate by SkidRow
Custom Front Winch Bumper by RoundStar OffRoad
Skyjacker Adjustable Rear Track Bar
Skyjacker Brake Line Extenders
Rock Krawler Adjustable Front Lower Control Arms
And Plenty of "CHARACTER" From rocks and Trees
07 JK Unlimited
33x11.5x16
#384
We lost power in the city over the weekend, 4wd's closed today, so the fax machine might need reset or something. There server went down,. So if its connected to that. it might be the reason also.
#386
How about some type of list on what level trails everyone is expecting to run?
Greens: Stocker friendly.
Green/ Light Blues: Stocker possible, need spotting, rock rails and skids helpful, more clearance preffered.
Blues: Clearance (lift and or tires), skids, spotting, Rock rails necessary, Differential protection, and Decent tread.
Blues/Blacksamage likely, skids, differential protection, rock rails, 35's minimum, Lift for clearance, winch, proper gearing, Lockers.
Blacks/Reds: Damage is going to happen, Lockers front and rear, Winch, Skids, Differential protection, Proper gearing, Rock rails, Rollover prtection, 35's minimum.
Now everyone has to understand you are taking your Jeep offroad and damage is possible, even on a Green trail. These listings are solely My opinion! Yes you can take a less equipped vehicle on a hogher ranked trail, but these are what I'd ne looking for if I was leading you!
BTW, might there be some wheelin' 101 and/or recovery courses available at this event?
#387
As a new wheeler & Rausch noob in my daily-driver Rubicon with 2.5" BB on 34" MT/Rs, I'll start on Green and probably gravitate pretty quickly to Blue. I'll be relocating my Evap Can and adding Diff skids, and maybe engine skid before then.
#388
#389
#390
Yep! Lesson learned and noted! By the way, did I tell you my Front locker was Toast! No wonder I had so many issues the day before climbing that Red hillclimb! Anyways, all back together for now, just trying to sort out some issues with that Gosh Darn lift I had installed! No fear David is here, and he's on the case. Hope to have resolution soon! It's getting frustrating to say the least!
