Want 35s, But Don’t Have a Lift Kit? No Problem!
It’s pretty easy to get the temptation to buy big tires. They are a simple and easy install that really helps the capabilities of your Jeep. And as a bonus, they look really cool. The only problem is that you can only get away with them if you have a lift kit. Bushwacker solves that problem by offering modified fender flares that will allow you to fit 35s on your newer Jeep Wrangler.
Made of composite plastic, these flares offer the same durability as your original fender flares, while also utilizing factory mounting locations to make installation as easy as possible. As a bonus, your inner fender liners remain in place to keep debris away from the engine bay while you tackle off-road trails.
These flares allow fitment of a 35-inch tire due to their flat shape, which gives added clearance over the curved OEM fender flares. As you can see in the video below, everything you need is included, and the only real work involved is a simple wire crimp for the side-marker lights. Otherwise, both front and rear flares are screwed in place in a matter of minutes.
Chime in with your thoughts on the forum. >>
