Rugged Ridge Rolls Out Exo-Top for Two-Door Wrangler
By -
Rugged Ridge
Have your weekend adventures been hampered by not having enough room in your soft top two-door Wrangler? Then you’ll certainly find this helpful.
Rugged Ridge, a Jeep accessory and parts company, has expanded its innovative Exo-Top to two-door Wranglers.  Previously offered strictly for the four-door Unlimited models, the accessory provides the utility of a factory roof rack with the kind of open air freedom you can only get from a soft top, as highlighted in an Off-Road.com report.
The Exo-Top has a 300-lb storage capacity and also features a Sun Slider, which allows the top to slide back with the release of just two clips, which can be operated from the driver’s seat.
Even better, installing the system seems to be relatively easy, since it’s a direct bolt on. The Exo-Top is also compatible with most other rack accessories offered for Wranglers, which all sounds like a win-win for Jeep fans.
Chime in with your thoughts on the forum. >>
via [Off Road]
