Ram 3500 is an Incredible JK Wrangler Hauler
Ram 3500 and Wrangler are both modified for off-road excellence, and the Jeep fits on the truck.
This unique Ram and Jeep Wrangler hauling combo comes to us from a recent AutoEvolution piece, but it might look familiar to those who didn’t see that piece. This pair of off-road machines was originally featured at the SEMA Show back in 2014 and it was built by the “Truck Guru”, Chris Payne. While the larger-than-life nature of this pair made for a fitting SEMA display, it was built to perform well in serious off-road settings.
With this combo, you could haul the Wrangler into the wilderness on the back of the Ram 3500 and when you get to your base camp, you could unload the Jeep and use it for more serious exploration of tight quarters. There is no question that the Wrangler will get in and out of the more-extreme off-road conditions, but if you break something, you have an insanely-capable off-road vehicle waiting back at camp.
2014 Jeep Wrangler
This Wrangler is fitted with a Bulletproof suspension setup that lifts the vehicle an adjustable range of six to eight inches. That makes plenty of room for the 18-inch American Force wheels wrapped in 35-inch Independence SS rubber. Behind those big wheels is a set of R1 Concept brake rotors and G2 axles with 4.88 gears help climb over and through everything.
This Jeep isn’t massively modified, but it has the upgrades needed to serve as an excellent off-road toy.
2014 Ram 3500
The 2014 Ram 3500 is the more heavily modified of these two machines. Not only has it been upgraded to be a better off-roader, but it is also equipped with a bed rack that holds the Jeep Wrangler.
First, this Ram 350 has an 8-10-inchsuspension setup from McGaughy with a custom coilover system from Fox. Out back, leaf springs paired with Firestone Ride Rite air bags handle the weight of the Jeep while still presenting a relatively comfortable ride. A set of 20-inch American Force wheels wrapped in 37-inch Toyo rubber will dig through just about anything while the R1 Concepts brake rotors help to slow down the large, heavy combo.
In addition to the suspension, brake and wheel-and-tire upgrades, this Ram 3500 is outfitted with aftermarket front and rear bumpers, a custom grille a 12,000-pound winch and – most significantly – the unique SMP FabWorks bed rack. That rack and the ramps leading to it are strong enough to handle the weight of the JK Wrangler in rough off-road conditions, although we have to imagine that low-hanging branches are going to beat up the Jeep.
We don’t know what engine is under the hood, but we would like to think that it is a Cummins Turbo Diesel. However, a modified Hemi V8 would be able to move this weight, but the diesel definitely has more working-torque potential.
Realistically, this isn’t a particularly cost effective off-road rig, but if you have a Ram 3500 and you don’t have a trailer, this is certainly an interesting option to get your Jeep to camp without driving multiple vehicles. At the same time, if you are going off-roading and you want to have two very different vehicles with which to play in the woods or mud, this is the perfect setup.
In any case, there is no question that this combo has more “wow factor” than any other truck-and-trailer setup.
Photos: AutoEvolution
