KC HiLites Flex Lights
By -
flex dual
KC HiLites brings Flex-ability with their new Flex LED Light system. Not only is the system available in spot, spot/flood, dual, or array types, but they can also be further arranged into stacked or longer with the right adapters. That means you could stack a pair of duals for a square combo, widen your 10-inch array to 20-inch, or even create a stacked 20-inch array.
flex array 10
The Flex LED Lights feature 10-watt Cree XM-L2 U2 LEDs, precision reflector optics, 50,000-hour LED life, and 5700K color temperature on Aluminum Housings that are IP68 rated and protect against EMI interference. Flex Dual LED lights come in either Spread or Spot beam pattern, though the 10-inch Flex Array comes in spot only. The 20-inch and 30-inch Flex Array Spot/Spread Combo and all Flex LEDs operate at 9 to 18 volts.
modular
Check out more at kchilites.com for more information and where to buy.
Chime in with your thoughts on the forum. >>
