Eibach All-Terrain-Level and All-Terrain-Lift Kits for JK
Eibach is getting into the Jeep JK Wrangler suspension game in a big way with their all new All-Terrain-Level leveling kit and All-Terrain-Lift 3-inch lift kit. With a legendary name like Eibach involved, you know these kits will have the leading engineering you’d expect from a world-wide, world-class company. Here’s a brief look at each kit.
The All-Terrain-Level performance suspension system is more than just a spring upgrade. It contains a set of Pro-Truck shocks that are perfectly matched, real world tested, and tough as nails. The shocks and springs are built in the USA and the shocks feature Nitro-Coated rods with 46mm pistons flowing through Eibach’s Maxima Shock Oil. The bodies are heavy-duty powered coated for long lasting looks. All of the hardware needed is included and it even comes with adjustable front sway-bar end-links.
The All-Terrain-Lift performance suspension system is a 3-inch lift kit that uses taller springs, which are not only better for off-road driving, but superior on-road handling and stability. They are matched to a set of Pro-Truck Shocks tuned for the lift springs. That’s not all: The kit includes a set of Bumpstop spacers, adjustable sway-bar end-links, adjustable front track-bar, rear track-bar location brackets, and longer stainless steel brake lines.
Both kits feature Eibach’s Million-Mile Spring Warranty and two-year Shock Warranty. Check out Eibach.com for more.
