Bronco Raptor Falls Well Short of Wrangler 392 Power
Bronco Raptor is the most capable Ford SUV, but it will still struggle to keep up with the Wrangler.
Since the Rubicon 392 was introduced, the Jeep Wrangler has held a commanding power lead in the world of high performance off-roading SUVs. With 470 horsepower, the naturally aspirated Hemi offers gobs more power than the twin turbocharged V6 in the Bronco at 330 horsepower, but we have known for some time now that a stronger, more capable Ford SUV was on the way in the form of a new Raptor.
Well, the Ford Bronco Raptor officially last month and, as expected, it has a stronger engine. However, with promise of “more than 400 horsepower”, the twin turbocharged 3.0-liter V6 is almost certainly going to be well behind the Wrangler 392.
Bronco Raptor Details
The Ford Bronco Raptor is far more than just a larger EcoBoost engine, as the Motor Company has made upgrades to legitimately make it a better off-road vehicle. Unfortunately for Ford off-roading fans, one of those upgrades is not a solid front axle.
Ford started by upgrading the chassis to include a fully-boxed frame made from lots of high strength steel with upgrade front and rear axle assemblies, widening the track by 8.6 inches. That made plenty of room for the 37-inch tires, the largest in the class, while the Raptor HOSS 4.0 race-ready suspension system with Fox Live Valve 3.1 dampers leads to 13.1 of ground clearance. To make room for the wider track, Ford added huge wheel flares that look like they came from the JC Whitney catalog.
Finally, as mentioned above, the Ford Bronco Raptor has a unique engine compared to the rest of the lineup. The twin turbocharged 3.0-liter EcoBoost V6 offers 400 horsepower and 415 lb-ft of torque in the Explorer ST and in the Bronco Raptor, Ford is promising more than 400 horsepower. Ford loves providing vague numbers for their performance vehicles before the vehicles actually come to market, but the actual number is usually not much higher than the “at least” number.
Wrangler 392 Vs Bronco Raptor
So the Bronco Raptor has a slightly bigger tire and a slightly more advanced suspension system than the Wrangler 392, but it will have to be proven in the real world whether those upgrades make it the better off-road vehicle. We have tested the Bronco Badlands with the Sasquatch package at the same off-road park as the Wrangler 392 Xtreme Recon and the Jeep was clearly more capable in every situation, even before looking at the power difference. Ultimately, the bigger, bulkier Bronco Raptor is going to struggle to keep up with the Wrangler 392 in tight quarters based on its size, but the chassis, suspension and tire upgrades may allow Ford to close the gap a bit.
As for power levels, we know that Ford has said that the Bronco Raptor will have more than 400 horsepower, per the press release. We also know that the same basic engine offers 400 horsepower and 415 lb-ft of torque in the Explorer ST and the 3.5-liter EcoBoost in the F-150 Raptor offers 450 horsepower and 510 lb-ft of torque. It is safe to say that the 3.0-liter V6 in the Bronco Raptor is not going to pack more power than the 3.5-liter EcoBoost in the F-150 Raptor, so it will likely be in the area of 425 horsepower and 450 lb-ft of torque.
If the Bronco Raptor has around 425 horsepower and 450 lb-ft of torque, it will fall well short of the Wrangler 392 at 470 horsepower and 470 lb-ft of torque. In addition to the horsepower and torque differential, the 392 offers quicker power delivery without the lag of the twin turbo V6. Oh, and the Wrangler weighs a couple hundred pounds less than the current Bronco, so the Raptor with beefier parts will likely be even heavier.
In short, the Bronco Raptor has less horsepower, less torque, weighs more and is bigger than the Wrangler 392, so while it might be the most off-road-capable Ford SUV, it will still struggle to keep up with the legendary Jeep.
Bronco images courtesy of Ford
Photos: Patrick Rall
