‘JKForum’ Member Lists a ‘Bombproof’ Jeep Wrangler in the Marketplace
Jeep Wrangler is built to handle the absolute roughest off-roading conditions with ease.
There are many members selling a Jeep Wrangler in the JK-Forum Marketplace, but from time to time, we will see a title that really jumps out at us. In this case, it was the inclusion of the word “bombproof” while mentioning a set of seriously heavy duty axles. Of course, we had to look and see what makes a JKU bombproof and upon reading through the listing, we imagine that this Wrangler could tackle the harshest off-road conditions.
This Jeep was listed by ACDCFiend with a price of $21,500, later reduced to $18,500. We aren’t sure if it would really handle a bomb going off under it, but aside from that, we don’t think that too many things would stop this Wrangler.
Bombproof Wrangler Introduction
When the OP first posted his 2008 Jeep Wrangler Unlimited for sale, he provided an extensive list of the modifications and upgrades made over the years.
No trades.
–Dynatrac Prorock 60 rear & Prorock 44 front axles (Extreme Duty model, 3″ tubing, 1/2″ wall, clearance is better than D30) see invoice and Dynatrac link for more info.
-Adams driveshafts 1310 F and R
–Eaton electric lockers
-Yukon 5.13 gearing
-Dynatrack ball joints, rebuildable
-Trail Dash tuner for max fuel and power use
-RCV shafts
-Poison Spider rocker guards
-WildBoar adventure rack
-Shrockworks armor
-Rubicon Express 3.5″ lift
-Currie OTK steering
-After market track bar brackets F&R welded on, not just bolted
–Rancho 9500 series adjustable shocks
-Rancho steering stabilizer
-Rugged Ridge mud mats
-Currie AntiRock Aluminum F swaybar
-Clayton adjustable OR control arms
-Toyo MT 37s on 17″ Procomps
-NEW Optima yellow top battery
-NEW Aluminum tie rod w/ 1 ton links
-NEW drag link
-NEW Timken hubs front
-NEW radiator, eng oil pan and gaskets, harmonic pulley sensor
-K&N cold air intake
-custom alum trunk cover for safe storage and gear organizing
-Mopar halfdoors
-Mopar soft top, NO hard top included
-Slime compressor mounted under psgr seat
-Teraflex heavy duty tire carrier
-TMPS sensors were removed, too vulnerable to breaks
-LOTS, LOTS MORE EXTRAS.-Ac/heat work perfectly. Aftermarket Viper alarm.
-Most of the wheeling has been overlanding. All maintenance has been kept up with VERY well. Have never had engine/transmission issues. Interior is in prestine condition. No accidents or mechanical/electrical problems.
As you can tell from this list, not only is this Wrangler heavily modified for off-road dominance, but there has been quite a bit of preventative maintenance performed, so it is both rugged and reliable. The OP also included 22 pictures, several of which we have included here. For more detailed pictures, click here to check out the full listing.
Turnkey Trail Beast
If you are looking for a Jeep Wrangler Unlimited that is ready to tackle the toughest off-road situations, you don’t need to look much further than this rugged JKU. It is heavily modified inside and out, but not to the point that it cannot be used for a road vehicle, provided that the tire fitment is legal in your area. It has the chassis and suspension bits needed to climb through the deepest, rockiest woods along with a massive roof rack, perfect for a bunch of cargo or a roof-mounted tent.
Ultimately, this 2008 Wrangler is the perfect option for someone who wants a badass Jeep to go off-roading, but they don’t have the time or knowledge to build one from a stock SUV.
Click here for a closer look or to ask the OP questions about this slick JKU.
