TeraFlex '05 TJ HEMI with CRD60's
Tons of info here.
http://www.teraflex.biz/teraflex-bui...mi-conversion/
One great thing about TeraFlex is that our employees are also our customers. Take our Vice President, Jeff Mock, for example. Jeff’s 2005 Unlimited has had quite a few TeraFlex overhauls in it’s short life time. From suspension systems to tires and wheels, even a HEMI engine. Take a look at some specs that are sure to make your mouth water…
Starting out, Jeff’s TJ was suped-up with a 5.7 Liter Hemi conversion and a 545RFE double overdrive 5 speed A/T. As you can imagine it goes a little bit faster than it did stock…
Underneath, the Jeep sits on top of a 4″TeraFlex PRO LCG lift supported by both front and rear TeraFlex CRD60 Axles, equipped with Air lockers. Also included in the package is a TeraFlex High Steer Kit, TeraFlex 975 Front Sway Bar, and TeraFlex 965 HD Rear Swaybar…talk about great handling.
