D-Ring Silencers (Stop The Clank)
Old Feb 27, 2008 | 03:58 AM
edstroyer's Avatar
Default D-Ring Silencers (Stop The Clank)
One of the annoyances I have when wheeling in the mud is the D-ring/Shackles clanking around. With this clanking, you will not be able to here any loose or broken part problems with your Jeep.
Well thanks to the BallCock Shank Washer, (LOL) I was able to prevent the D-Rings from clanking. Sorry for the bad camera pix...
You may need to file them down a bit, but they work and look great!
Old Feb 27, 2008 | 04:06 AM
07JKX's Avatar
wow... that looks great... i just keep my tow strap up front and that prevents the clanking... nice mod!
HappyCurmudgeon's Avatar
Eternal ***erator
Great minds... great minds...
I have nearly the same setup on mine, my stepfather was a plumber/pump repairman so i have stacks of old plumbing stuff, found some old rubber grommets that look very similar and have them on mine. (Only difference is i have my pins ziptied so they wont rotate out and go missing)
Old Feb 27, 2008 | 08:05 AM
kntr's Avatar
I used an old set of mountain bike handlebar grips and cut them to fit. They work perfect.
Old Feb 27, 2008 | 08:13 AM
BLKRUBI's Avatar
Great idea! Thanks. What d-rings did you find to fit the Mopar bumper?
Old Feb 27, 2008 | 09:36 AM
edstroyer's Avatar
The ARB 3/4 D-rings fit. You can get them from Quadratec http://www.quadratec.com/products/92144_301.htm.
One thing I notice when I got my Mopar bumpers was the D-ring holes weren’t properly cut. The Hole were imperfect. I used my dremel to grind a perfect 3/4 hole and repainted with Satin Black Rustoleum.
Old Feb 27, 2008 | 09:37 AM
BLKRUBI's Avatar
Yup, same here. Thanks for the info.
Old Feb 27, 2008 | 09:50 AM
mikeyfl's Avatar
wost product name ever.
Old Feb 27, 2008 | 09:52 AM
Eternal ***erator
But available to ship from San Francisco without delay.
Old Feb 27, 2008 | 10:19 AM
Hoovis's Avatar
With these, do the D-rings still clank when you hit a bump? I have been using rubber washers I got from the plumbing dept. at a hardware store (about $0.40 each so $1.60 per shackle mount). It stops any side to side clanking but not the up/down clanking, which really only happens when I hit speed bumps.
But I'm curious to know if these stop all clanking.
