Cool Tech UltraMount Antenna System.
Old 08-25-2007, 11:20 AM
07 RBY's Avatar
Question Cool Tech UltraMount Antenna System.
Has anybody installed one yet? Any hitches or problems with instructions? I going to do it later on today, or tomorrow. Thanks.
Old 08-25-2007, 12:33 PM
DCMP001's Avatar
Default cool tech
I installed the kit. Pretty easy and works well. Really high quality stuff. I don't think you will be dissapointed.
Old 08-25-2007, 04:09 PM
07 RBY's Avatar
I'm stuck on step 10, where you drill the hole. I'm not sure which piece it is supposed to be in. The following steps are confusing as well.
Old 08-26-2007, 11:31 PM
07 RBY's Avatar
OK, me and a buddy figured out where to put the hole for the antenna. I made it a little too big, so I need to put some black RTV around it. Now all I need to do is mount and hook up the CB.
Old 08-27-2007, 11:13 AM
07 RBY's Avatar
OK, I have it mounted on my side of the console. I need to figure where to connect to power. I looked under the hood, but only found one place on the drivers side. I can't get anything else through it. It seems to be solid metal behind it. The rubber grommet flexes enough for me to feel metal behind it. Any ideas?
Old 08-27-2007, 11:17 AM
jeeper's Avatar
Hey 07rube, got any pics of that antenna mount for us?
Old 08-27-2007, 11:19 AM
rizorizzo's Avatar
Old 08-27-2007, 12:29 PM
07 RBY's Avatar
Alright, already. Hold your horses. Here's some pics.
Notice I put some black sealer around the hole because I drilled it way too big.
Old 08-27-2007, 03:28 PM
kb7our's Avatar
Default Oversize CB Mount Hole
"I put some black sealer around the hole because I drilled it way too big."
Making the hole too big can happen if you are off just a little where you drill the hole and where the mount base needs to poke through. A large rubber washer from the local hardware store that has an inside lip will also work and makes for a clean install. Not really a need to use sealant to keep water out if you simply drill a small hidden hole in the bottom of the license plate bracket (like the mirror mod hole) for water to drain out. Just another option.
Old 08-27-2007, 04:23 PM
jeeper's Avatar
Thanks 07rube, that looks like the best antenna mount for a JK so far. I also like the way you're mounting the radio. I have looked inside mine and couldn't think of a good way to mount a CB. So far your idea is looking very good.
Thanks again!
Quick Reply: Cool Tech UltraMount Antenna System.
