Drilled the side view mirrors!
Old 12-15-2006, 05:10 PM
Rubimon's Avatar
Default Drilled the side view mirrors!
I washed my Jeep today for the second time. The mirrors drip water for days and leave spots all over the side of the jeep. I read a thread about drilling a weep hole so I gave it a whirl. The first mirror I removed and tried doing the v-cut in the gasket like the thread said. (too much hassel) I ended up drilling a tiny hole underneath where the flat part of the mirror meets the round part (just above the gasket seal inside) and put it back on. I went to the other side and decided to just drill and not remove the mirror. My mirror was pissing like a race horse! Good quick fix! The hole just needs to be tiny.
Old 12-15-2006, 05:38 PM
Piginajeep's Avatar
Pics?
ID:	247127   Click image for larger version
ID:	416345   Click image for larger version
ID:	416349   Click image for larger version
ID:	416351   Click image for larger version
ID:	576875   Click image for larger version
ID:	576876   Click image for larger version
ID:	576877   Click image for larger version
ID:	576878   Click image for larger version
Old 12-15-2006, 11:17 PM
Rubimon's Avatar
It's a little hard to see on the black.[IMG][/IMG]
RhinoJK_18 (07-22-2020)
Old 12-16-2006, 07:08 AM
Robar's Avatar
Thanks the pic helped a bunch.
Did you drill straight in or go in at an upward angle?
Old 12-16-2006, 09:12 AM
Rubimon's Avatar
At a slight upward angle. It's just plastic so go slow. If you do it after you wash it water squirts right out as soon as it breaks through. I have to think a lot of that water seeps into your door panel after seeing how it mounts inside.
ID:	252115   Click image for larger version
ID:	252116   Click image for larger version
ID:	252117   Click image for larger version
ID:	252118   Click image for larger version
ID:	252120   Click image for larger version
ID:	252121   Click image for larger version
ID:	252122   Click image for larger version
ID:	252123   Click image for larger version
ID:	252125   Click image for larger version
ID:	252126   Click image for larger version
ID:	252127   Click image for larger version
ID:	252128   Click image for larger version
ID:	252130   Click image for larger version
ID:	252131   Click image for larger version
ID:	252132   Click image for larger version
ID:	252133   Click image for larger version
Old 12-16-2006, 09:49 AM
tolh13's Avatar
their be water in those mirrors.that was easy...and lots of water just sitting in side. thanks
ID:	252442   Click image for larger version
ID:	252443   Click image for larger version
Old 12-16-2006, 11:01 AM
2K1TJ's Avatar
I've always wondered, do race horses really piss more than regular horses?? :confused:
ID:	253006   Click image for larger version
ID:	253007   Click image for larger version
ID:	253008   Click image for larger version
ID:	253009   Click image for larger version
ID:	253011   Click image for larger version
Old 12-16-2006, 11:19 AM
Robar's Avatar
That was easy. Thanks for the tip.
I had green water draning out. I could have been raising skeetos.
Old 12-16-2006, 11:53 AM
Rubimon's Avatar
No, just faster!
ID:	253480   Click image for larger version
ID:	253481   Click image for larger version
ID:	253482   Click image for larger version
ID:	253483   Click image for larger version
ID:	253485   Click image for larger version
ID:	253486   Click image for larger version
ID:	253488   Click image for larger version
Old 12-16-2006, 12:53 PM
jeepinoutwest's Avatar
Non-race horses pee when the urge hits. Race horses have to hold their pee till they are done racing, hense more backup and pressure.
ID:	253953   Click image for larger version
ID:	253954   Click image for larger version
ID:	253955   Click image for larger version
ID:	253956   Click image for larger version
ID:	253958   Click image for larger version
ID:	253959   Click image for larger version
ID:	253960   Click image for larger version
ID:	253961   Click image for larger version
ID:	253963   Click image for larger version
ID:	253964   Click image for larger version
ID:	253965   Click image for larger version
ID:	253966   Click image for larger version
ID:	253968   Click image for larger version
ID:	253969   Click image for larger version
ID:	254278   Click image for larger version
ID:	254279   Click image for larger version
ID:	255017   Click image for larger version
ID:	255018   Click image for larger version
ID:	255019   Click image for larger version
Quick Reply: Drilled the side view mirrors!
