What size spacers for my stock X wheels and M/Ts
Old Nov 20, 2009 | 10:55 AM
93cbra's Avatar
Default What size spacers for my stock X wheels and M/Ts
Hi guys, I'm thinking of buying some BF M/Ts for the winter and putting them on my stock X 16" steel wheels. Do you know what size spacers I would need in order to do this?
Also, can anyone tell me how wide the stock 08 X steel wheels are?
Old Nov 20, 2009 | 10:58 AM
what size tire
Old Nov 20, 2009 | 11:14 AM
93cbra's Avatar
Originally Posted by JEEP THRILLS
what size tire
Probably 255/70/16
Old Nov 20, 2009 | 11:16 AM
nthinuf's Avatar
Try the FAQ's that you skipped over, pasted right up at the top of this section.
But...
Those tires are 30x10x16. You don't need spacers. Stock on rubicons and opt sahara is 32x10
From the faq's:
X Standard
Painted Steel - Size 16 x 7.0
Backspacing on all factory wheels is 6.25"
Read this section also
Q: What is the biggest size tire I can fit on my stock Jeep JK Wrangler?
Old Nov 20, 2009 | 12:08 PM
YellowToy's Avatar
You should consider getting Rubicon take-offs instead. A larger tire & you can probably pick up a full set of 5 on the rims for around $500.
Old Nov 20, 2009 | 02:25 PM
mghornet's Avatar
I ran 265 75 16 BFG's on the steel rims till I lifted mine. No rubbing issues
Old Nov 21, 2009 | 07:45 PM
pastorsteve's Avatar
You can certainly use spacers on your factory wheels and tires without issue. You can use 1.5" spacers. I don't see any reason to switch to 16" wheels but it's your call. Spacers can be used in stock form or with a lift and larger tires. If you just want to bring your wheels out to fill out your wheel wells and widen your stance a little - go for it.
Old Nov 21, 2009 | 07:48 PM
07rubisteve's Avatar
X2....with the 1.5 inch spacers, our rigs (with OEM wheels) look awesome, they should be that way from the factory..
Old Nov 23, 2009 | 01:56 AM
93cbra's Avatar
Thanks guys, I appreciate the info!
Old Nov 23, 2009 | 05:49 PM
the_cuse420's Avatar
Default forget em
you wont need them ive had 265/75/16 on mine for 4months and not a problem yet.
