Is this bad, really bad, or not bad at all?
Old Nov 3, 2009 | 08:10 PM
PoorDad's Avatar
You may want to consider getting some new diff covers. The stock ones are very thin and some have a tendency to hang down lower than the pumpkin and get caught up on rocks. Thats what messed up my stock diff cover. I got some Riddler covers and have not had to worry about my diff covers since.
Old Nov 3, 2009 | 08:20 PM
RedneckJeep's Avatar
Just clean it off. It'll take for frikkin ever to make a difference in the level seepin that slowly.
Old Nov 3, 2009 | 08:25 PM
nwjk's Avatar
No drips no problem. Mine looks the same and the dealer says its ok, however they did reseal the rear diff and replace the pinion seal under warranty.
Old Nov 3, 2009 | 08:33 PM
toymaster's Avatar
Originally Posted by saltman
If you can change your oil, you can change your dif fluid. The RTV is not complete there and it is leaking. You need to drain the fluid, pull the cover, remove old rtv, replace with new (or lube locker) and refill with fluid. piece of cake. It should be done every 12-15K anyway.
Mostly correct but try 50K plus and that is if you over do it and are anal, 100K is conservative. (And some manufactures have specs that say lifetime if it is synthetic fluid from the factory)
Originally Posted by toad
No. Just drain it all out, wipe it down with some paper towels and then spray the brake cleaner in there and wipe it out as well. Make sure to scrape off as much RTV as you can. You might also want to file the edges just to get a better contact for the RTV. Apply it, wait for about 10 mins then replace the cover. Then, go ahead and re-fill it..there is no need to wait.
99% right and she a GIRL. Just don’t forget to clean the mating surfaces of the cover and housing and let them dry before adding the RTV to ONE of them. Spraying the gears is way over the top unless you can see metal shaving in there and if you do see metal shaving you have bigger problems anyway.
Originally Posted by RN M OVR
I have that all over my diffs -- since I changed my diff oil. That's all it is, oil/now grease. I wouldn't worry about this. The common scenario is your differential breather hose pushed some oil out, because you have had too much in, when going over a bump or driving at highway speeds. That, or it can even been coolant or washer fluid that spouted out when going over a bump. Or maybe your sealant needs replacing.
I would definitely change the sealant between diff cover and the diff next time you change the oil. In the meantime I would not worry about this. Your JK is 100% fine. Just watch to see if the stains get any worse or begin drippinng on your garage floor.
True this minor seepage is nothing to worry about unless you are anal (which I am) but you can plainly see this is coming from the cover seal not the breather tube. Also the lube locker gaskets are really nice but RTV is way cheaper and you can get it at any auto parts place even you local walmart.
Old Nov 3, 2009 | 08:36 PM
cwhitfield's Avatar
Originally Posted by JK Freedom
I hope that you changed the oil of the engine before 12k
Ahh, so that's what the change oil indicator was for... I thought it meant that it was time to put more 3in1 oil on the hinges...
Old Nov 3, 2009 | 08:58 PM
mkjeep's Avatar
Good God!!! It's not salvagable, Trade it before the top starts leaking aswell!!!!!
Just kiddin, it's no biggie, drain and re-rtv as others have said.
Old Nov 3, 2009 | 09:49 PM
08leocon's Avatar
x2 and call it a jeep thing
Old Nov 3, 2009 | 10:03 PM
toymaster's Avatar
OK, after a second look, I have changed my mind..... it is total lose better not even try to drive it any more.....look since your a nice guy I'll do you a favor and haul the whole heep off for you....want even charge you anything.
After some serious shop time I'll get it running, maybe.
Old Nov 3, 2009 | 11:46 PM
ClaytonTheAggie's Avatar
LOL! Nice try, but I'll pop a hole in the floorboard and fred flintstone it if it comes to that!
Nah, seriously thanks for all the input, ya'll. I'll get some RTV and go to town! I want to eventually get some beefier diff covers, but right now the money is an issue and it's the lift I'm spending money on first.
Yet another problem solved on my favorite forum
Old Nov 4, 2009 | 04:38 AM
  #20
CSquareSahara's Avatar
Not to get off track, but how did the bedlining of the bumpers go? I'm thinking about doing that as well. Got any pics of the results?
