LoD
Old 11-03-2009, 11:44 AM   #31
levosgien
levosgien's Avatar
levosgien is offline
Quote:
Originally Posted by whpony96 View Post
You need to bend the metal "grips" that hold the light bulb, down flat. Make sure they do not touch the back of circuit board at all. Then cut the bulb adapter completely off and solder the wires to the back of the light housing. I then glued the LED board with Plumbers Goop to the light housing right in the center.
Crap I was thinking this would be plug and play Anyways to do this without having to glue the whole thing down permanently (just in case I can my mind later, or if I sell my car and the guy wants a good old bulb).
I guess my questions is, are there other alternatives as insulators between the flattened bulb holders and the back of the circuit?
Thanks!
Old 11-03-2009, 11:58 AM   #32
whpony96
whpony96's Avatar
whpony96 is online now
As low priced as it would be to replace them I would not even worry about it! Make it nice for yourself don't worry about the next guy down the line!
__________________
08 Rubi Ultd Stone White
Teraflex 3" Lift Kit & Frt Trk Bar
16" PC 1079 and 35" GY MT\R Kevlar's
Cobra 75 w/ Cool Tech mnt.
Mopar Htd Seats
"Rescue" badges
Flashpaq w\ XDI CAI
Woods Hood Lift & Rear Door Shock & SS reloc kit
Gibson Quad Tip SS
MyGIG Lockpick & Multi Cable w\Mic & RV cam
True HID Bi-Xenon Headlights and Fogs 8000K
Viair HD Onboard Air
Oznium LED Rock Lights
Riddler F\R Diff Cvrs
Changed all bulbs to LEDS
Wife that works on it with me..
Old 11-03-2009, 02:35 PM   #33
levosgien
levosgien's Avatar
LOL damnit. In that case you can easily fit two of those, I don't know why someone said that only 16 works, you can fit two of those lengthwise no problem
Old 11-03-2009, 02:40 PM   #34
whpony96
whpony96's Avatar
The 16 is the only one that will fit due to the width.. if you get the bigger one it will not fit in the housing..now as for 2 16 boards fitting in one housing you might be cutting it close. But once you have one board in there you see how bright it is...there is really no need for 2 of them in one housing....
__________________
Mopar Htd Seats
"Rescue" badges
Flashpaq w\ XDI CAI
Gibson Quad Tip SS
Old 11-03-2009, 02:49 PM   #35
levosgien
levosgien's Avatar
Right, but if I'm going to be soldering anyways I would just recommend going with 2 x 16 and solder them together....no?
Old 11-03-2009, 03:00 PM   #36
whpony96
whpony96's Avatar
Oh you can solder 2 boards together. But, I don't know if they will fit in the housing together side by side....
__________________
Mopar Htd Seats
"Rescue" badges
Flashpaq w\ XDI CAI
Gibson Quad Tip SS
Old 11-03-2009, 03:05 PM   #37
levosgien
levosgien's Avatar
Yea they should fit, I was checking with mine that's why I was a little confused. If you can push them flush against the bulb holders and they are not pressing against the concave transparent plastic should work.
Old 11-03-2009, 03:30 PM   #38
whpony96
whpony96's Avatar
I say go for it and don't forget to post some before, during and after pics...
__________________
Mopar Htd Seats
"Rescue" badges
Flashpaq w\ XDI CAI
Gibson Quad Tip SS
Old 11-03-2009, 04:30 PM   #39
SCF
SCF's Avatar
SCF is offline
Pardon the lack of grey matter usage here...
So, you remove the housing from the vehicle. Bend down the tabs flag against the housing. Then solder the LED leads to the rear of the housing. Does it matter + or - placement?
Thanks!
__________________
Fred
"You don't stop laughing because you grow old, You grow old because you stop laughing."
Old 11-03-2009, 05:29 PM   #40
levosgien
levosgien's Avatar
Quote:
Thanks!
I don't think that it matters which way you solder. The way you can check is by plugging in the led via the adapter each way, or even the stock bulb.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Teaka Trucks
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
