Why run dual batteries in a JK?
First of all, the OEM JK battery just doesn’t last. There are many reports of them dying without warning after only 1-2 years. They simply aren’t up to the rigors of off-road use. On top of that, the JK has more electronics than any previous Wrangler. Just considering the OEM electronics, the factory battery, and most single batteries are at max capacity. Once you start adding off-road lights, a winch, inverter, air compressor, data/nav/comm equipment, fridge, etc you quickly surpass what a single battery can effectively and reliably deliver. Often, these additional electrical demands are seen during extreme temperatures when batteries are weakest. You don’t want to find out you have a battery problem in the extreme desert heat or during a snowstorm.
A pair of high quality batteries and a well engineered dual battery system makes those problems non-issues. With either of Benchmark Designs Dual Battery Packages, you always have a “Main” battery and an “Aux” battery. The Main battery only runs the OEM Jeep electronics, including starting the Jeep. The Aux battery powers all of your accessories, and offers the ability to self jump start the Main Battery.
Beyond redundancy and load sharing, an Aux battery also offers the feature of being able to run accessories for extended periods of time with the engine off. Whether it’s a fridge being run all night, an inverter at camp, or even an air compressor, you don’t ever have to worry about periodically restarting the Jeep.
____________________________
JK “K.I.S.S.” Dual Battery Package
Here’s a complete dual battery package for your JK. This kit includes everything you need, nothing you don’t. Sometimes the simplest solution is the best! This kit has 2 modes, “Key-On” and “Key-Off”. With the ignition in the run position, the batteries are combined and stay charged and available for heavy electrical loads like winching and starting. With the ignition turned off, the batteries are isolated. This preserves the Main Battery for restarting the Jeep, and the Aux Battery is used to run accessories, such as an inverter, fridge, lights, compressor, etc. Restart the vehicle using the Main Battery, and they’re automatically combined to recharge the Aux Battery.
This kit includes the dual battery tray and all necessary mechanical pieces for mounting Group 34 Optima or Odyssey PC1500 type batteries. It also includes all the wiring, switching solenoid, new heavy duty marine-type battery lugs, and heavy duty 2 gauge power and ground cables already assembled.
This kit is the complete bolt-in solution. Installation is very simple and requires only basic hand tools. No cutting or fabrication required whatsoever. Just add batteries. This kit is weatherproof.
Price: $330
______________________________________________
JK “Smarty” Dual Battery Package
If you’re into the bells and whistles, this one’s for you. This is a complete JK kit with a sophisticated “Smart Isolator”. The Smart Isolator uses voltage sensing circuits to monitor individual battery levels and automatically isolate and combine the batteries. When both batteries are above 13.2V, they’re automatically combined. When they dip below 12.V, they’re automatically isolated until the Main Battery has been recharged by the alternator to greater than 13.2V, at which point they’re recombined so the Aux Battery can be recharged. This always keeps the Main Battery charged for starting, and allows the Aux Battery to power accessories for extended periods of time without running the engine, and without the risk of draining your Main Battery.
This kit includes the dual battery tray and all necessary mechanical pieces for mounting Group 34 Optima or Odyssey PC1500 type batteries. It also includes all the wiring, Smart Isolator, new heavy duty marine-type battery lugs, heavy duty 2 gauge power and ground cables, fuses and fuse holders.
Price: $400
