Rotating banners with links
+ Reply to Thread
Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 24
Thread: Clutch in water question
  1. #1
    JK Super Freak horwitzs's Avatar
    Join Date
    Jun 2007
    Location
    Dayton, WA
    Posts
    1,163
    Default Clutch in water question
    Ok, this is probably a newbie-type question, but my wrenching background is motorcycles, which have totally different clutch systems...
    When preparing for water crossings, we extend our breather hoses on the diffs, tranny and transfer case, but why is nothing done to protect the clutch to allow shifting while fording?
    Isn't there a way to cover or relocate the clutch venting to a higher spot?
    Again, I don't really know how auto clutches are setup, so maybe there is an obvious answer to this. I just need some enlightenment.
    Life is tough. It's tougher if you're stupid.
    Northridge4x4
    -Seth; '07 Rubi
  2. #2
    JK Enthusiast SCF's Avatar
    Join Date
    Apr 2007
    Location
    Weare, NH
    Posts
    464
    Nope, no way to seal the clutch to keep the water out. With a clutch, either stay out of deep water (my suggestion after toasting a TOB and pilot bushing the last time I did it), or don't shift.
    This is a pretty cool read of the old military CJs and water fording.
    Fred
    "You don't stop laughing because you grow old, You grow old because you stop laughing."
  3. #3
    Join Date
    Jun 2007
    Location
    Dayton, WA
    Posts
    1,163
    Default Follow-up question
    Ok, so say I'm in water in 4-low, moving in 3rd gear or something, and need to downshift to go much slower or creep along for some reason...
    The JK will start without the clutch in 4-low. So can I shut it off, change to 1st or 2nd gear without the clutch, then restart and continue on my way? Or will I be unable to restart because water has entered the muffler while the engine was stopped?
    Northridge4x4
    -Seth; '07 Rubi
  4. #4
    Join Date
    Jul 2009
    Location
    State College, PA
    Posts
    303
    Quote Originally Posted by horwitzs View Post
    My suggestion would be to go into water in 1st gear in 4-low. There shouldn't be any reason to need to go any faster than that in deep water (as going faster tends to cause waves and bad things to happen). I have had a lot of success in 1st and 4-low during water crossings. Granted when I felt like I was going to get stuck I have bounced off my redline during parts of many crossings, but why else have a red-line if you aren't going to use it 4-low and 1st should still also allow you to go fast enough to keep up the momentum to not get stuck in the mud if its a deep water/mud crossing. Remember slow and steady wins the race
    '08 JK Unlimited
    Steel Blue Metallic
    6-Speed
    MBRP Stainless Steel Off-road Exhaust
  5. #5
    JK Junkie TripleJeep_99's Avatar
    Join Date
    Oct 2007
    Location
    Revelstoke, British Columbia
    Posts
    3,872
    Quote Originally Posted by tpm152 View Post
    I am kinda the same 4LO...either 1st gear in muddy crossing with soupy mud. With gravel bottom rivers/crossings 2nd gear works out great. If you stall in 2nd gear just throw it into 1st gear and start it up without the clutch if in 4LO.
    2008 Jeep Wrangler Sahara Unlimited
    6spd, 3:73 limited Slip Rear
    OME HD coil springs with RE Mono-shocks
    JKS Adj Trac Bars
    Tera Flex Front LCA's
    LoD Mid-Width & skid plate
    LoD rear bumper/tire carrier
    Warn XD9000i
    H4 IPF headlights
    IPF 968 Windshield lights & MBRP Brackets
    AEV Snorkel
    Superchips programer
    17x8 Eagle Alloy Series 140
    Cooper STT 33x12.5R17
    Need:
    LoD rock sliders
    No 35's for this family guy
    www.northridge4x4.ca
  6. #6
    Join Date
    Feb 2009
    Location
    Sydney, NSW
    Posts
    324
    Quote Originally Posted by TripleJeep_99 View Post
    I don't want to sound dumb here as I've had my JK a year now & thought I knew my Jeep's features pretty well.
    So you can start the JK in gear if in 4Low? I certainly know that in 4High or 2High you need to depress the clutch first to activate the starter; or are you saying that depressing the clutch when the motor's off won't risk clutch damage if the tranny's submerged?
  7. #7
    Join Date
    Jun 2007
    Location
    Dayton, WA
    Posts
    1,163
    Yep, in 4-low you can start without depressing the clutch.
    The ratio is low enough that the starter can fire the engine and get the wheels rolling a bit and on your way.
    You don't want to press the clutch while under water, regardless of motor running or not. It will suck water in.
    Northridge4x4
    -Seth; '07 Rubi
  8. #8
    Join Date
    Feb 2009
    Location
    Sydney, NSW
    Posts
    324
    Cheers for the info! I always thought it was a bit wierd that an off-roader couldn't be turned over in gear, considering this feature is essential in some situations. I'll have to go out now & try it...
  9. #9
    JK Super Freak adamisadam's Avatar
    Join Date
    Nov 2008
    Location
    Long Island, NY
    Posts
    1,775
    wow! cool article on military CJs. they eventually got those jeeps to be able to ford 74'' of water! now THAT'S water fording!
    and for clutches, they used positive crankcase pressure to pressurize engine & eventually bellhousing. driver had to insert a drain plug at the bottom of bellhousing before water crossing. ... and put ob his bathing suit I guess!!!
    BTW, there are many books, manuals, & web sites that tell us techniques for off roading, like how to use the started to get over rocks insteat of riding clutches & tips like that. I'd suggest reading them. Mark Smith from jeep jamboree fame has one they give out with each jamboree registration. that was a good read. even the owners manual has good tips.
    enjoy!
  10. #10
    JK Junkie Suffolk JK's Avatar
    Join Date
    Jan 2008
    Location
    Long Island, NY
    Posts
    2,423
    How about just staying away from deep water, that's a thought.
    2008 Jeep Wrangler X 2DR dubbed RED WONDER WAGON by Evan
    Lots of mods.
    Long Island Off Road Club
    NOVA4x4
+ Reply to Thread
Page 1 of 3
1 2 3 LastLast
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
