Rattle when accelerating
Old 04-10-2014 | 11:28 AM
JKUCH5's Avatar
Default Rattle when accelerating
Has anyone had this problem when you accelerate there is rattle from below the drivers seat under the Jeep? From inside the car it sounds like its under the hood but when you stand outside the car its under the Jeep, almost sounds like it could be the exhaust line.
JKU Sahara 2007.
Thanks-
JK
Old 04-10-2014 | 11:36 AM
Jade_Monkey07's Avatar
Yeah I get this 1 when dirt accumulates on top of the skid and rattles against the exhaust. 2 when I mashed my skid to the point it was just touching the exhaust
I dont always drive where others cant. but when I do, its in my Jeep. Stay muddy my friends
Old 04-10-2014 | 11:37 AM
Zroe's Avatar
Any rattle under acceleration, is most likely related to the exhaust. Just get under the Jeep and man handle the different parts of the exhaust until you can reproduce the sound. Don.t forget all those heat shields that may be rubbing up against it too.
Old 04-11-2014 | 02:52 PM
rdubb1031's Avatar
Is this the noise you're hearing? I've had two rattles under the front in the past.
1. loose bolt on the control arm
2. (noise below) I've been trying to track this one down and it turns out on the exhaust pipe that cross under the JK from passenger to driver has some sort of plate clipped to the top. There appears to be one of the "clips" taht is broken. This is metal, which is surprising. I just tracked this down today so I'm not sure on how it can/shoudl be fixed. It doesn't appear to be a big issue, just annoying. Has anyone come across this? Any suggestions.
ID:	544916Click image for larger version
https://www.youtube.com/watch?v=9KfKLCeY1Fg&feature=youtu.be
Old 04-11-2014 | 02:59 PM
Weld it....
Old 04-11-2014 | 03:15 PM
travltek's Avatar
Same here: bent skid plate contacting crossover exhaust pipe
Old 04-11-2014 | 03:25 PM
scooby snacks's Avatar
Mine rubs the rear cross member :(
Old 04-11-2014 | 03:34 PM
I took off the skid and fixed it with a bfh
Old 04-11-2014 | 08:03 PM
Ryan0260's Avatar
Could just be one of the heat shields. Check for broken welds on them. A quick fix is to wedge a washer between the shield and pipe.
Old 04-12-2014 | 10:21 AM
ouroborus2012's Avatar
Attachment 544916Attachment 544917
I had this same problem and so have many of us... Go get a pipe clamp like this Shop 4-in dia. x 4-in L Galvanized Full Clamp at Lowes.com
tighten it on there and BAM, no more rattle
