cloudy headlights
Haven't had or seen of that problem at least here in Ca., I suppose if you are in extremely cold weather then this could happen? I would immagine that after the lights have been on for a while then they should clear up?
Probably just another Jeep anomoly!
I think I read something about it somewhere. It might have been a TSB.
If it's just cloudy, jeep is calling it normal. Basically it's just a little condensation, but I know it would drive me off the wall if I had a new headlight that looked like that.
If there's actual water in the head lamp, it's possible you have a faulty or cracked lamp.
Maybe you can try to see if your dealership will replace it? Otherwise, just turning the lights on will clear it up temporarily (I have to wonder if it makes lights die quicker though.)
Just want to know: Have you driven through water???
Thanks for the replies. My Jeep is a 08 2 door X. It was bought in December, and no, it hasn't been driven in water. I did replace the factory bulbs with the Sylvania ones that have been talked about on here about 3 week ago. They don"t seem to ever clear up, even after having the lights on for a good while. I did find a TSB on it, but it was for the early 07's.
Maybe the seals on the sylvanias are crappy? All I know is I tried everything to dry out the damn things. I pulled the lights off and used a blow dryer for 30 minutes. I used paper towels. I used silica gel beads. nothing. It would go away for a few days and come right back, progressively worse
I put silverstars in my fogs and headlight the day i bought the jeep. Had it about 6 months now and no problems. Every now and then they look foggy but mostly right after i wash it but after the lights burn a few mins it goes away. I hope over time this does not cause any problems and it sucks they havent made any aftermarket parking or corner lights also
