2013 Automatic with CEL P0741 - Dealer issues
Got the CEL - Torque Converter Clutch Solenoid Circuit Performance or Stuck On.
Light came on while traveling across Pennsylvania three weeks ago. All is fine except when at hwy speeds and you are climbing a long up hill grade. Seems like you are low on power so you push the gas more and more. RPMs jump up and then you go. CEL pops up. 43,000 miles. Took it in, dealer agreed with code, had to wait 2 weeks for appointment. Problem continuing in between. Dealer called today and said they believe the big wheels and tires are to blame, confusing the torque converter.
Nitto Trail Grappler 295/75/17 on Procomp 17x9.5 rims. Ran these most of last summer, and since this spring. Stocks on for winter.
First off, Big tires on a Jeep is very common...everyone does it. I got the tiresizing from them. Store down the road from them told me to go to the dealer to check out the two jeeps they just modded for them...love the wheels and tires, went back to store and told them to copy exactly.
So, I told dealer all of this...if big tired are too much for transmission, why are you selling them that way on your lot?
They are going to change trans filter and fluid as well as both axels. Will cost me $600, and told me to put the stock wheels back on and see what happens. Sorry so long, your opinions are appreciated.
big tires dont confuse the torque converter, these jeeps dont use GPS for speed, so as far as the jeep is concerned when you piut bigger tires on, the speedometer to the human is wrong but the wheel RPM to transmission is the same, even changing that doesnt cause issues as people regear their axles all the time without issue..
its true when pumping a hill that the converter unlocks, sometimes for a long period of time to help give you power, it may even shift out of overdrive down a gear as well, neither of those should hurt it.. (other than running converter unlocked can run the trans temp up pretty quickly)..
what dealer are you going to? if its performance, get it outta there, if its crown then im surprised as ive had good luck with them and they seem Mod friendly from what ive seen / heard.
-Christopher
-Christopher
It is at Automax Chyrsler Dodge Jeep(formally Carriage Town). He is not blaming diameter. He is saying the weight. I guess towing a 3,500 lb trailer is ok, but not and extra 100 lb of rubber. What is worst, he said if he turned in the warranty request and listed the tires, they would likely get turned down. He didn't,t even ask. He told me put the stockers back on and see if it happens again.
I am going to take my business somewhere else. I thought I heard it all...I was wrong.
-Christopher
-Christopher
of course if you change things with flashpaq the computers are going to react differently..
what I said was just if you changed the tire size out the jeep has no idea its physically moving faster then before.. . extra large tires can make the jeep work harder.. which as mentioned should be no different than towing a trailer..
the engine to tailshaft ratio never changes, which is where i believe that code comes from is it thinks the converter clutch wither should be engaged and isnt or isnt engaged and should be.. at least thats the way the old GM's were.. just looked at Engine RPM vs tail-shaft sensor speed..
-Christopher
-Christopher
Update: took Jeep to different dealer. They look up bulletins, found that in the date code on my transmissions was made during a time frame that they had manufacturing issues with the input shaft. jeep told them not to rebuild it, and sent a brand new transmission. All covered under the 50,000 mile power train warrantee.
First dealer will never see me look there way again!!
