NEW Rigid Industries SR-M Flush Mount Back Up Light Kit
Old 10-30-2013 | 02:58 PM
Offroad_Elements's Avatar
Former Vendor
Default NEW Rigid Industries SR-M Flush Mount Back Up Light Kit
*A disclaimer before going any further. I am not a professional mechanic. These steps worked for me and are only meant as a guide.
I am extremely impressed with this kit and decided to do a quick write up from my experience last night.
Rigid Industries SR-M Back Up Kit | Offroad Elements
If you're interested in following the way I did this, I will gladly send along some Posi-Tap connectors with your order.
Tools:
Philips head screw driver
Dremel Tool
Allen Keys
Drill & 7/32” Drill Bit
Wire Cutters / Strippers
Wire Connectors
Remove factory tail light with a Philips head screw driver. Place SR-M gasket over the clear lens as a guide for cutting.
Fit the light and mark holes. Use 7/32” drill bit to make pilot holes. The ¼” bolts provided will tap into these quite easily.
I only wanted to tap these into the existing factory wiring, so I cut the harness it came with.
I used Posi-Tap connectors to on the end of the newly cut harness.
Connect new harness connects to old factory reverse light harness - positive to positive, negative to negative. Wrap up/waterproof old plug, and bundle everything together with electrical tape to avoid rattles.
Test to make sure it lights up. Re-install and that’s it!
The output is incredible, I look forward to backing up now.
Old 10-30-2013 | 03:31 PM
brikino's Avatar
Thanks for the write up! Seems simple and very effective. Any issues with the CANBUS not liking the SR-M's?
P.S. Like how you went with a Halloween theme on the Jeep with the skeleton.
Old 10-30-2013 | 06:35 PM
DesertJeep's Avatar
That's a great idea. Thanks for the write-up.
Old 10-30-2013 | 06:44 PM
TJM12's Avatar
Great idea!
Old 10-30-2013 | 06:52 PM
DesertJeep's Avatar
Do the SR-Ms come with gaskets to make a watertight seal? If not, what did you do to seal the join?
Old 10-30-2013 | 06:54 PM
Former Vendor
No issues with the electrical system after this install.
Old 10-30-2013 | 06:56 PM
Former Vendor
They do come with a rubber gasket. Shown in first photo.
Old 10-30-2013 | 07:33 PM
rodi's Avatar
ah this is great. need to order a set.
Old 10-30-2013 | 08:07 PM
nvglockster's Avatar
Thanks for the write-up!
Old 10-31-2013 | 05:18 AM
red09's Avatar
great write up. Been looking at a solution for the poor lighting back there and this seems to be it.
Hook those into an Spod and you can use them for trail work lights if needed.
Quick Reply: NEW Rigid Industries SR-M Flush Mount Back Up Light Kit
